can't boost more then 30psi ???
Hello,
I was mapping my car yesterday and I cant get my Evo 9 JDM GSR to go more then 30psi when I go over 30psi its like I hit a brick wall the ECU is cutting the power but only when I go over 30psi I am using ECU FLASH I have HKS EVC boost controller so I am not using the factory boost controller is there a setting in ECU FLASH of is it the MAP sensor ? My JDM map sensor is 3 bar could it be maxed out ??
I am hitting 374 Load with 29.8psi I am running AMS GT900X
Hope some one can help me
ROM 89980000
what do you think about what they told me ?
My Max load so far is 376 but I can't go higher because of the fuel cut boost
My load is 374 but when it goes to over 30psi id does like a fuel cut I need to map this baby to 35psi I am using 109 octane sunoco. on lancer ragester they told me to set Boost delay timer from 1000 to 10000 and my map is set to 380 load so I also need to set it to 420 load
ROM 89980000
ROM 89980000
As far as your map, you don't *need* to map out to 420 load. You can to get better control of fueling from your last load now to 420, but it isn't necessary. The ECU will use your last load column to account for fueling past that column.
While this isn't your problem, it would be a good idea to add this so that you have control over 380 load. So, get this done.
If you have your boost delay timer at 1000, then that's your problem. Either do the patch that enables your boost cust to go above 319 or move your timer to a number you won't hit, like 100000. You are hitting fuel cut because of this table.
Blitz_b9
Apr 10, 2012 04:16 PM
