throttle tip-in and timing
in V7's peryphery bits there is "timinig knock down at throttle tip in"
can someone explain this function and tell me should it be on or off ?
currently I have it on, and experiencing some knock counts at sharp throttle tip-in and part throttle acceleration. can it be the reason ?
there is incorrect name in my first post, there should be "timing knock down at light throttle and under 3000 rpm"
it's somewhere in FAA bits if I remember correctly
no, I haven't triet turning it off yet
Hey did you switch it off??? Did it fix your knock issue?? I know what and where the bits are. In interested in the knock issue. I turned mine off and still knocks on spool up!
Check this thread for more info on what this setting does.
https://www.evolutionm.net/forums/ec...your-maps.html
