DSM / Eclipse 1995 Evoscan Coolant temp RAW x Scaled
Old Jul 24, 2011 | 02:42 PM
luizdiefenbach's Avatar
Ok, here is the problem: the supplied eval for coolant temp is
Coolant Temp 07 -1.45x + 308 deg F
gives a wrong temp, starts high and lowers as the car is getting warmer.
After a lot of search I found that if I use only x as eval on request id 07 I get the RAW coolant temp in Celsius.
I tested this and seems right BUT the ecu uses the SCALED / CORRETED value for turning fans, etc...
So the eval for scaled coolant temp should be x-?? (as the raw its a little higher than scaled)
Anyone knows how many degrees the raw and scaled differs on the 95 dsm?
Or if some one have a ir/laser thermometer it could easy log requestid 07 with eval x and see the the difference with the thermometer.
Sorry for my english, and thanks in advance for the help.
Old Jul 25, 2011 | 01:15 AM
MercenaryX2's Avatar
Code:
<DataListItem DataLog="N" Color="" Display="Coolant Temp Scaled" LogReference="CoolantTempScaled" RequestID="10" Eval="1.8*x-40" Unit="deg F" MetricEval="x-40" MetricUnit="deg C" ResponseBytes="1" GaugeMin="-40" GaugeMax="260" ChartMin="-40" ChartMax="260" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
That's what you should have for Coolant Temp Scaled. Put that line in your Mitsubishi MUTII file located in your Evoscan folder.
mrfred
Aug 1, 2022 07:05 AM
3VOLUTIONIST
Dec 19, 2020 03:23 AM
Hiram6g74
Apr 13, 2017 09:59 PM
GST Motorsports
113
Feb 14, 2017 07:09 AM
Dynotech Tuning
Sep 20, 2016 02:30 PM
