JDM MAP Sensor pin-outs
Hi guys,
I installed the JDM 3 Bar MAP sensor last night according to the instructions posted on here, so that I can do ECU based boost control in the near future.
Anyway, the sensor's not working properly (just getting a constant 0.8V reading), so I'm hoping that the sensor pin-outs I researched and found on the net are wrong. I have a JDM Evo 8 so had no existing wiring or sensor in the car.
I used:
Pin 1 - ground
Pin 2 - signal
Pin 3 - 5V
Having looked through the USDM service manual, it looks like the wiring should be:
Pin 1 - signal
Pin 2 - ground
Pin 3 - 5V
Can someone please check and confirm this? Not too keen on wiring it up again wrong!
If I do already have it correctly wired, I'll pull the sensor out and run a vacuum test on it.
Cheers
I used:
Pin 1 - ground
Pin 2 - signal
Pin 3 - 5V
Pin 1 - signal
Pin 2 - ground
Pin 3 - 5V
Cheers
Alchem1st
Mar 15, 2022 08:47 AM
Evo_AK
16
Sep 28, 2015 12:26 PM
Lion_Sam
May 5, 2015 05:49 AM
tboboy
Aug 7, 2010 03:39 PM
