understanding LTFT low
Ok so im trying to tune my injectors for minimal or at least decent fuel trim error. I have a 2003 Evo VIII with PTE 1000cc injectors. I was able to dial in my LTFT Mid to about -0.39% which was more then satisfactory for me.
I started in on the LTFT Low as it was maxed out from -12.5% and the STFT at idle was around -20%. I lowered the 14v and 11v latencys in steps of 12-15% and got the STFT to hover around 0% but the LTFT Low stayed at the -12.5%. This makes sense if the value learned by the ecu to keep stoic is -12.5% so the STFT hovers around 0%. I then adjusted the latencys further and was able to get the STFT to hover around +12% and the LTFT Low is at -12.5%. Easy math here tells us that they cancel each other out. Almost... Myproblem is that the LTFT Low never moves from the -12.5% position even though the STFT is constantly between +10-16% What gives?
Ive pasted a section of the idle log in the next post so you can see.
Any help on this would be greatly appreciated. I did have the car idling for at least 16 min if I remember correctly. Im just sick of wasting time and fuel trying to get these injectors to a good state. I dont know if other people have this much trouble dialing them in. Of course there was a learning curve here...
Thanks for any help
Ethan
Thanks for any help
Ethan
This log was taken with EvoScan. O2Feedback = STFT Fuel Trim. FYI
LogEntrySeconds | LogNotes | TPS | RPM | TimingAdv | KnockSum | Battery | KnockVoltage | Load1B | JDMMAP | WideBandAF | InjPulseWidth | InjDutyCycle | FuelTrim_Low | FuelTrim_Mid | O2FeedbackTrim |
38.77171 | 13.7254902 | 968.75 | 14 | 0 | 13.9327 | 0.156 | 33.6 | -4.43956 | 14.6853 | 1.536 | 1.16 | -12.5 | -3.90625 | 11.71875 | |
38.84169 | 13.7254902 | 937.5 | 18 | 0 | 14.00603 | 0.1365 | 33.6 | -4.8265 | 14.6853 | 1.536 | 1.24 | -12.5 | -3.90625 | 11.71875 | |
38.91169 | 13.7254902 | 1000 | 12 | 0 | 14.00603 | 0.468 | 32.4 | -5.01997 | 14.7441 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.5234375 | |
38.98175 | 13.7254902 | 1000 | 8 | 0 | 14.00603 | 0.0975 | 33.6 | -4.43956 | 14.7441 | 1.536 | 1.24 | -12.5 | -3.90625 | 11.71875 | |
39.05179 | 13.7254902 | 937.5 | 16 | 0 | 14.00603 | 0.1365 | 33.6 | -4.43956 | 14.7441 | 1.536 | 1.2 | -12.5 | -3.90625 | 11.9140625 | |
39.12173 | 13.7254902 | 1000 | 15 | 0 | 14.07936 | 0.2145 | 33.6 | -5.01997 | 14.7294 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.9140625 | |
39.1917 | 13.7254902 | 1031.25 | 5 | 0 | 13.9327 | 0.1755 | 32.4 | -4.63303 | 14.7294 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.109375 | |
39.2617 | 13.7254902 | 1000 | 10 | 0 | 13.9327 | 0.195 | 33.6 | -4.43956 | 14.1267 | 1.536 | 1.2 | -12.5 | -3.90625 | 12.109375 | |
39.33081 | 13.7254902 | 968.75 | 16 | 0 | 14.07936 | 0.156 | 32.4 | -5.01997 | 14.1267 | 1.536 | 1.28 | -12.5 | -3.90625 | 12.3046875 | |
39.40369 | 13.7254902 | 1062.5 | 7 | 0 | 14.00603 | 0.234 | 32.4 | -4.8265 | 14.1267 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.5 | |
39.47373 | 13.7254902 | 1000 | 6 | 0 | 14.07936 | 0.0975 | 32.4 | -4.8265 | 14.6706 | 1.536 | 1.24 | -12.5 | -3.90625 | 12.6953125 | |
39.5437 | 13.7254902 | 968.75 | 14 | 0 | 14.00603 | 0.1365 | 32.4 | -5.21344 | 14.6706 | 1.536 | 1.28 | -12.5 | -3.90625 | 12.6953125 | |
39.61371 | 13.7254902 | 1031.25 | 11 | 0 | 13.9327 | 0.156 | 32.4 | -4.63303 | 14.7588 | 1.536 | 1.36 | -12.5 | -3.90625 | 12.890625 | |
39.68269 | 13.7254902 | 1031.25 | 3 | 0 | 14.00603 | 0.078 | 32.4 | -5.21344 | 14.7588 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.890625 | |
39.75269 | 13.7254902 | 1000 | 11 | 0 | 14.07936 | 0.2535 | 32.4 | -5.21344 | 14.9499 | 1.536 | 1.24 | -12.5 | -3.90625 | 13.0859375 | |
39.8227 | 13.7254902 | 1000 | 12 | 0 | 14.00603 | 0.0975 | 32.4 | -4.63303 | 14.9499 | 1.536 | 1.36 | -12.5 | -3.90625 | 13.0859375 | |
39.89268 | 13.7254902 | 1093.75 | 4 | 0 | 14.07936 | 0.156 | 32.4 | -5.40691 | 14.9352 | 1.536 | 1.36 | -12.5 | -3.90625 | 13.28125 | |
39.96271 | 13.7254902 | 1031.25 | 7 | 0 | 13.9327 | 0.1755 | 32.4 | -4.8265 | 14.9352 | 1.536 | 1.24 | -12.5 | -3.90625 | 13.4765625 | |
40.03272 | 13.7254902 | 1000 | 15 | 0 | 14.00603 | 0.1755 | 32.4 | -4.8265 | 14.9352 | 1.536 | 1.32 | -12.5 | -3.90625 | 13.671875 | |
40.10271 | 13.7254902 | 1062.5 | 7 | 0 | 14.00603 | 0.351 | 32.4 | -5.40691 | 14.994 | 1.536 | 1.36 | -12.5 | -3.90625 | 13.671875 | |
40.17269 | 13.7254902 | 1031.25 | 7 | 0 | 14.07936 | 0.156 | 32.4 | -4.8265 | 14.994 | 1.536 | 1.32 | -12.5 | -3.90625 | 13.8671875 | |
40.24271 | 13.7254902 | 1000 | 13 | 0 | 14.07936 | 0.0975 | 32.4 | -5.40691 | 15.1851 | 1.536 | 1.32 | -12.5 | -3.90625 | 13.8671875 | |
40.3127 | 13.7254902 | 1062.5 | 10 | 0 | 14.07936 | 0.1365 | 32.4 | -4.63303 | 15.1851 | 1.536 | 1.4 | -12.5 | -3.90625 | 14.0625 | |
40.38184 | 13.7254902 | 1062.5 | 6 | 0 | 14.00603 | 0.1365 | 32.4 | -5.40691 | 15.1851 | 1.536 | 1.32 | -12.5 | -3.90625 | 14.2578125 | |
40.45176 | 13.7254902 | 1000 | 12 | 0 | 13.9327 | 0.1755 | 32.4 | -5.21344 | 15.2292 | 1.536 | 1.32 | -12.5 | -3.90625 | 14.2578125 | |
40.52182 | 13.7254902 | 1062.5 | 12 | 0 | 14.07936 | 0.117 | 32.4 | -5.21344 | 15.2292 | 1.536 | 1.4 | -12.5 | -3.90625 | 14.453125 | |
40.59172 | 13.7254902 | 1093.75 | 5 | 0 | 14.00603 | 0.1755 | 31.2 | -5.60038 | 15.3174 | 1.536 | 1.32 | -12.5 | -3.90625 | 14.2578125 | |
40.6617 | 13.7254902 | 1000 | 12 | 0 | 14.07936 | 0.2145 | 32.4 | -4.8265 | 15.3174 | 1.536 | 1.28 | -12.5 | -3.90625 | 14.2578125 | |
40.73172 | 13.7254902 | 1031.25 | 15 | 0 | 14.07936 | 0.0975 | 32.4 | -5.40691 | 15.435 | 1.536 | 1.36 | -12.5 | -3.90625 | 14.0625 | |
40.80175 | 13.7254902 | 1093.75 | 5 | 0 | 13.85937 | 0.3315 | 31.2 | -4.8265 | 15.435 | 1.536 | 1.36 | -12.5 | -3.90625 | 14.0625 | |
40.8717 | 13.7254902 | 1031.25 | 8 | 0 | 14.00603 | 0.2925 | 31.2 | -5.40691 | 15.435 | 1.536 | 1.32 | -12.5 | -3.90625 | 13.8671875 | |
40.94371 | 13.7254902 | 1000 | 14 | 0 | 13.9327 | 0.156 | 32.4 | -5.01997 | 15.4203 | 1.536 | 1.32 | -12.5 | -3.90625 | 13.8671875 | |
41.01375 | 13.7254902 | 1062.5 | 10 | 0 | 14.07936 | 0.156 | 31.2 | -5.21344 | 15.4203 | 1.536 | 1.4 | -12.5 | -3.90625 | 13.671875 | |
41.0837 | 13.7254902 | 1062.5 | 5 | 0 | 14.00603 | 0.1365 | 31.2 | -4.8265 | 15.288 | 1.536 | 1.28 | -12.5 | -3.90625 | 13.671875 | |
41.1537 | 13.7254902 | 1000 | 14 | 0 | 14.07936 | 0.156 | 32.4 | -5.40691 | 15.288 | 1.536 | 1.32 | -12.5 | -3.90625 | 13.4765625 | |
41.22384 | 13.7254902 | 1031.25 | 12 | 0 | 13.9327 | 0.1365 | 32.4 | -5.01997 | 13.9356 | 1.536 | 1.36 | -12.5 | -3.90625 | 13.4765625 | |
41.29369 | 13.7254902 | 1062.5 | 7 | 0 | 13.85937 | 0.117 | 32.4 | -5.01997 | 13.9356 | 1.536 | 1.28 | -12.5 | -3.90625 | 13.28125 | |
41.3637 | 13.7254902 | 1000 | 14 | 0 | 14.00603 | 0.195 | 32.4 | -5.40691 | 13.9356 | 1.536 | 1.28 | -12.5 | -3.90625 | 13.28125 | |
41.43368 | 13.7254902 | 1031.25 | 13 | 0 | 14.07936 | 0.1365 | 33.6 | -4.63303 | 14.7147 | 1.536 | 1.4 | -12.5 | -3.90625 | 13.0859375 | |
41.50287 | 13.7254902 | 1062.5 | 5 | 0 | 14.15269 | 0.429 | 32.4 | -5.40691 | 14.7147 | 1.536 | 1.32 | -12.5 | -3.90625 | 13.0859375 | |
41.57346 | 13.7254902 | 1000 | 10 | 0 | 14.07936 | 0.273 | 32.4 | -4.8265 | 14.5971 | 1.536 | 1.28 | -12.5 | -3.90625 | 12.890625 | |
41.64275 | 13.7254902 | 1031.25 | 15 | 0 | 13.9327 | 0.195 | 32.4 | -5.21344 | 14.5971 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.890625 | |
41.71273 | 13.7254902 | 1093.75 | 4 | 0 | 14.00603 | 0.156 | 32.4 | -5.21344 | 14.6559 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.6953125 | |
41.78279 | 13.7254902 | 1062.5 | 7 | 0 | 13.9327 | 0.0975 | 32.4 | -5.01997 | 14.6559 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.6953125 | |
41.85274 | 13.7254902 | 1062.5 | 13 | 0 | 14.07936 | 0.1365 | 32.4 | -5.40691 | 14.6559 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.5 | |
41.92272 | 13.7254902 | 1125 | 5 | 0 | 14.00603 | 0.2925 | 31.2 | -5.40691 | 14.7588 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.5 | |
41.99281 | 13.7254902 | 1062.5 | 8 | 0 | 14.07936 | 0.0975 | 31.2 | -5.60038 | 14.7588 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.3046875 | |
42.06275 | 13.7254902 | 1031.25 | 14 | 0 | 13.9327 | 0.1755 | 32.4 | -5.01997 | 14.4207 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.3046875 | |
42.13335 | 13.7254902 | 1125 | 6 | 0 | 14.00603 | 0.2925 | 31.2 | -5.21344 | 14.4207 | 1.536 | 1.44 | -12.5 | -3.90625 | 12.3046875 | |
42.20468 | 13.7254902 | 1093.75 | 4 | 0 | 14.07936 | 0.1365 | 31.2 | -5.40691 | 14.3766 | 1.536 | 1.36 | -12.5 | -3.90625 | 12.3046875 | |
42.27471 | 13.7254902 | 1031.25 | 13 | 0 | 14.07936 | 0.234 | 32.4 | -5.40691 | 14.3766 | 1.536 | 1.36 | -12.5 | -3.90625 | 12.3046875 | |
42.3447 | 13.7254902 | 1093.75 | 12 | 0 | 14.07936 | 0.117 | 32.4 | -5.40691 | 14.3766 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.109375 | |
42.41469 | 13.7254902 | 1093.75 | 7 | 0 | 14.00603 | 0.156 | 31.2 | -5.40691 | 14.553 | 1.536 | 1.36 | -12.5 | -3.90625 | 12.3046875 | |
42.4868 | 13.7254902 | 1062.5 | 11 | 0 | 14.00603 | 0.1755 | 32.4 | -5.40691 | 14.553 | 1.536 | 1.36 | -12.5 | -3.90625 | 12.3046875 | |
42.55676 | 13.7254902 | 1062.5 | 12 | 0 | 13.9327 | 0.117 | 32.4 | -5.60038 | 14.5971 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.109375 | |
42.62673 | 13.7254902 | 1062.5 | 11 | 0 | 13.9327 | 0.312 | 32.4 | -5.21344 | 14.5971 | 1.536 | 1.28 | -12.5 | -3.90625 | 12.109375 | |
42.69674 | 13.7254902 | 1031.25 | 16 | 0 | 14.07936 | 0.1365 | 32.4 | -5.60038 | 14.8029 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.9140625 | |
42.76673 | 13.7254902 | 1093.75 | 7 | 0 | 14.00603 | 0.117 | 32.4 | -5.01997 | 14.8029 | 1.536 | 1.4 | -12.5 | -3.90625 | 11.9140625 | |
42.83671 | 13.7254902 | 1062.5 | 7 | 0 | 14.07936 | 0.273 | 32.4 | -5.79385 | 14.8029 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.71875 | |
42.90615 | 13.7254902 | 1031.25 | 14 | 0 | 13.9327 | 0.117 | 32.4 | -4.8265 | 14.8617 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.71875 | |
42.97611 | 13.7254902 | 1062.5 | 9 | 0 | 14.00603 | 0.1755 | 32.4 | -5.60038 | 14.8617 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.5234375 | |
43.04885 | 13.7254902 | 1031.25 | 10 | 0 | 13.9327 | 0.234 | 32.4 | -5.21344 | 14.9058 | 1.536 | 1.28 | -12.5 | -3.90625 | 11.5234375 | |
43.1187 | 13.7254902 | 1031.25 | 15 | 0 | 14.07936 | 0.1365 | 32.4 | -5.01997 | 14.9058 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.328125 | |
43.18873 | 13.7254902 | 1062.5 | 11 | 0 | 14.00603 | 0.39 | 31.2 | -5.60038 | 14.7441 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.328125 | |
43.25777 | 13.7254902 | 1031.25 | 10 | 0 | 14.00603 | 0.1365 | 32.4 | -4.8265 | 14.7441 | 1.536 | 1.28 | -12.5 | -3.90625 | 11.328125 | |
43.32791 | 13.7254902 | 1000 | 14 | 0 | 14.00603 | 0.0975 | 32.4 | -5.21344 | 14.7441 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.1328125 | |
43.39771 | 13.7254902 | 1031.25 | 12 | 0 | 14.00603 | 0.156 | 32.4 | -5.01997 | 14.4501 | 1.536 | 1.4 | -12.5 | -3.90625 | 11.1328125 | |
43.46792 | 13.7254902 | 1062.5 | 4 | 0 | 14.07936 | 0.1365 | 32.4 | -5.21344 | 14.4501 | 1.536 | 1.32 | -12.5 | -3.90625 | 10.9375 | |
43.5377 | 13.7254902 | 1000 | 12 | 0 | 14.07936 | 0.117 | 33.6 | -5.40691 | 14.406 | 1.536 | 1.28 | -12.5 | -3.90625 | 10.7421875 | |
43.60783 | 13.7254902 | 1000 | 12 | 0 | 14.00603 | 0.0975 | 33.6 | -4.63303 | 14.406 | 1.536 | 1.36 | -12.5 | -3.90625 | 10.7421875 | |
43.67769 | 13.7254902 | 1062.5 | 7 | 0 | 13.9327 | 0.1755 | 32.4 | -5.40691 | 14.4648 | 1.536 | 1.32 | -12.5 | -3.90625 | 10.546875 | |
43.74774 | 13.7254902 | 1000 | 11 | 0 | 13.85937 | 0.234 | 33.6 | -5.21344 | 14.4648 | 1.536 | 1.24 | -12.5 | -3.90625 | 10.7421875 | |
43.81769 | 13.7254902 | 1000 | 15 | 0 | 14.00603 | 0.0975 | 33.6 | -4.43956 | 14.4648 | 1.536 | 1.32 | -12.5 | -3.90625 | 10.7421875 | |
43.88771 | 13.7254902 | 1031.25 | 9 | 0 | 14.07936 | 0.312 | 33.6 | -5.21344 | 14.4942 | 1.536 | 1.36 | -12.5 | -3.90625 | 10.9375 | |
43.95672 | 13.7254902 | 1031.25 | 6 | 0 | 14.00603 | 0.117 | 33.6 | -4.8265 | 14.4942 | 1.536 | 1.28 | -12.5 | -3.90625 | 10.9375 | |
44.02972 | 13.7254902 | 968.75 | 14 | 0 | 14.07936 | 0.2535 | 33.6 | -4.63303 | 14.3619 | 1.536 | 1.28 | -12.5 | -3.90625 | 10.9375 | |
44.09973 | 13.7254902 | 1031.25 | 11 | 0 | 13.9327 | 0.2925 | 33.6 | -4.63303 | 14.3619 | 1.536 | 1.36 | -12.5 | -3.90625 | 10.9375 | |
44.1697 | 13.7254902 | 1062.5 | 2 | 0 | 14.00603 | 0.1365 | 32.4 | -5.40691 | 14.7 | 1.536 | 1.32 | -12.5 | -3.90625 | 10.9375 | |
44.23972 | 13.7254902 | 1000 | 9 | 0 | 14.00603 | 0.195 | 33.6 | -5.21344 | 14.7 | 1.536 | 1.28 | -12.5 | -3.90625 | 11.1328125 | |
44.30874 | 13.7254902 | 1031.25 | 14 | 0 | 14.00603 | 0.117 | 32.4 | -4.8265 | 14.7 | 1.536 | 1.4 | -12.5 | -3.90625 | 11.1328125 | |
44.37873 | 13.7254902 | 1093.75 | 4 | 0 | 14.07936 | 0.117 | 32.4 | -5.40691 | 14.7147 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.328125 | |
44.44871 | 13.7254902 | 1031.25 | 7 | 0 | 14.00603 | 0.156 | 32.4 | -4.8265 | 14.7147 | 1.536 | 1.28 | -12.5 | -3.90625 | 11.5234375 | |
44.51869 | 13.7254902 | 1031.25 | 14 | 0 | 14.00603 | 0.156 | 32.4 | -5.40691 | 14.8323 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.5234375 | |
44.58872 | 13.7254902 | 1093.75 | 8 | 0 | 13.9327 | 0.4875 | 32.4 | -4.8265 | 14.8323 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.71875 | |
44.65876 | 13.7254902 | 1031.25 | 8 | 0 | 14.00603 | 0.1365 | 32.4 | -5.40691 | 14.5971 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.9140625 | |
44.72873 | 13.7254902 | 1000 | 14 | 0 | 14.07936 | 0.156 | 32.4 | -5.01997 | 14.5971 | 1.536 | 1.28 | -12.5 | -3.90625 | 11.9140625 | |
44.79873 | 13.7254902 | 1031.25 | 13 | 0 | 14.00603 | 0.1755 | 32.4 | -5.21344 | 14.5971 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.109375 | |
44.86881 | 13.7254902 | 1062.5 | 5 | 0 | 14.07936 | 0.117 | 32.4 | -5.40691 | 14.8617 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.3046875 | |
44.93874 | 13.7254902 | 1000 | 12 | 0 | 13.9327 | 0.2145 | 33.6 | -4.63303 | 14.8617 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.3046875 | |
45.0088 | 13.7254902 | 1062.5 | 11 | 0 | 14.00603 | 0.1365 | 32.4 | -5.60038 | 14.994 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.5 | |
45.07772 | 13.7254902 | 1093.75 | 4 | 0 | 13.9327 | 0.1755 | 31.2 | -4.8265 | 14.994 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.5 | |
45.14772 | 13.7254902 | 1031.25 | 11 | 0 | 14.07936 | 0.117 | 32.4 | -5.21344 | 14.4207 | 1.536 | 1.28 | -12.5 | -3.90625 | 12.6953125 | |
45.21771 | 13.7254902 | 1031.25 | 14 | 0 | 14.07936 | 0.1755 | 32.4 | -5.01997 | 14.4207 | 1.536 | 1.36 | -12.5 | -3.90625 | 12.890625 | |
45.28772 | 13.7254902 | 1062.5 | 7 | 0 | 14.00603 | 0.3315 | 31.2 | -5.40691 | 14.4207 | 1.536 | 1.36 | -12.5 | -3.90625 | 13.0859375 | |
45.35804 | 13.7254902 | 1031.25 | 9 | 0 | 13.9327 | 0.1365 | 32.4 | -5.21344 | 15.2145 | 1.536 | 1.32 | -12.5 | -3.90625 | 13.0859375 | |
45.42782 | 13.7254902 | 1031.25 | 13 | 0 | 13.85937 | 0.156 | 32.4 | -5.21344 | 15.2145 | 1.536 | 1.36 | -12.5 | -3.90625 | 13.0859375 | |
45.49774 | 13.7254902 | 1093.75 | 7 | 0 | 14.00603 | 0.3315 | 31.2 | -5.40691 | 15.2439 | 1.536 | 1.36 | -12.5 | -3.90625 | 13.0859375 | |
45.57009 | 13.7254902 | 1062.5 | 8 | 0 | 14.00603 | 0.0975 | 32.4 | -5.01997 | 15.2439 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.890625 | |
45.64009 | 13.7254902 | 1031.25 | 14 | 0 | 14.07936 | 0.195 | 32.4 | -5.60038 | 15.3174 | 1.536 | 1.36 | -12.5 | -3.90625 | 12.890625 | |
45.70971 | 13.7254902 | 1093.75 | 8 | 0 | 14.00603 | 0.195 | 32.4 | -5.01997 | 15.3174 | 1.536 | 1.36 | -12.5 | -3.90625 | 12.6953125 | |
45.77971 | 13.7254902 | 1062.5 | 8 | 0 | 14.00603 | 0.0975 | 31.2 | -5.60038 | 15.3174 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.6953125 | |
45.84974 | 13.7254902 | 1031.25 | 14 | 0 | 13.9327 | 0.312 | 32.4 | -5.01997 | 15.2439 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.5 | |
45.91973 | 13.7254902 | 1093.75 | 8 | 0 | 14.00603 | 0.1365 | 31.2 | -5.60038 | 15.2439 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.5 | |
45.98975 | 13.7254902 | 1062.5 | 5 | 0 | 14.00603 | 0.2145 | 31.2 | -5.01997 | 15.1263 | 1.536 | 1.36 | -12.5 | -3.90625 | 12.3046875 | |
46.05872 | 13.7254902 | 1031.25 | 12 | 0 | 14.07936 | 0.2535 | 32.4 | -5.21344 | 15.1263 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.3046875 | |
46.12874 | 13.7254902 | 1062.5 | 11 | 0 | 14.00603 | 0.156 | 32.4 | -5.21344 | 14.994 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.109375 | |
46.19871 | 13.7254902 | 1093.75 | 6 | 0 | 14.00603 | 0.312 | 31.2 | -5.40691 | 14.994 | 1.536 | 1.36 | -12.5 | -3.90625 | 12.109375 | |
46.26882 | 13.7254902 | 1031.25 | 10 | 0 | 13.9327 | 0.1755 | 31.2 | -5.40691 | 14.994 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.9140625 | |
46.33877 | 13.7254902 | 1062.5 | 13 | 0 | 13.9327 | 0.2145 | 32.4 | -5.21344 | 14.6265 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.9140625 | |
46.4087 | 13.7254902 | 1062.5 | 9 | 0 | 14.07936 | 0.2535 | 31.2 | -5.79385 | 14.6265 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.71875 | |
46.47871 | 13.7254902 | 1000 | 13 | 0 | 14.00603 | 0.117 | 32.4 | -4.63303 | 14.4207 | 1.536 | 1.28 | -12.5 | -3.90625 | 11.71875 | |
46.54869 | 13.7254902 | 1031.25 | 13 | 0 | 14.00603 | 0.2145 | 32.4 | -5.40691 | 14.4207 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.5234375 | |
46.61878 | 13.7254902 | 1062.5 | 8 | 0 | 13.85937 | 0.1755 | 32.4 | -5.21344 | 14.4354 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.5234375 | |
46.68872 | 13.7254902 | 1000 | 11 | 0 | 13.85937 | 0.1365 | 32.4 | -4.8265 | 14.4354 | 1.536 | 1.24 | -12.5 | -3.90625 | 11.328125 | |
46.75785 | 13.7254902 | 1000 | 16 | 0 | 14.00603 | 0.0975 | 33.6 | -5.21344 | 14.4354 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.328125 | |
46.82794 | 13.7254902 | 1031.25 | 9 | 0 | 14.00603 | 0.1755 | 32.4 | -4.8265 | 14.3325 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.1328125 | |
46.89785 | 13.7254902 | 1031.25 | 6 | 0 | 14.07936 | 0.117 | 32.4 | -4.8265 | 14.3325 | 1.536 | 1.24 | -12.5 | -3.90625 | 11.1328125 | |
46.9677 | 13.7254902 | 968.75 | 15 | 0 | 14.07936 | 0.156 | 33.6 | -5.40691 | 14.4207 | 1.536 | 1.28 | -12.5 | -3.90625 | 10.9375 | |
47.03774 | 13.7254902 | 1031.25 | 10 | 0 | 13.9327 | 0.1755 | 32.4 | -4.63303 | 14.4207 | 1.536 | 1.36 | -12.5 | -3.90625 | 10.9375 | |
47.1097 | 13.7254902 | 1031.25 | 7 | 0 | 14.00603 | 0.195 | 32.4 | -5.01997 | 14.4354 | 1.536 | 1.28 | -12.5 | -3.90625 | 10.7421875 | |
47.17972 | 13.7254902 | 968.75 | 14 | 0 | 14.00603 | 0.117 | 33.6 | -5.21344 | 14.4354 | 1.536 | 1.28 | -12.5 | -3.90625 | 10.7421875 | |
47.24971 | 13.7254902 | 1031.25 | 9 | 0 | 14.00603 | 0.195 | 32.4 | -4.63303 | 14.4354 | 1.536 | 1.36 | -12.5 | -3.90625 | 10.546875 | |
47.31994 | 13.7254902 | 1031.25 | 4 | 0 | 14.07936 | 0.195 | 33.6 | -5.21344 | 14.4942 | 1.536 | 1.28 | -12.5 | -3.90625 | 10.7421875 | |
47.3897 | 13.7254902 | 1000 | 12 | 0 | 14.00603 | 0.0975 | 33.6 | -4.8265 | 14.4942 | 1.536 | 1.24 | -12.5 | -3.90625 | 10.9375 | |
47.45969 | 13.7254902 | 1000 | 11 | 0 | 13.9327 | 0.156 | 32.4 | -4.8265 | 14.5089 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.1328125 | |
47.52977 | 13.7254902 | 1093.75 | 4 | 0 | 13.9327 | 0.1365 | 32.4 | -5.40691 | 14.5089 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.1328125 | |
47.59971 | 13.7254902 | 1031.25 | 11 | 0 | 13.9327 | 0.117 | 33.6 | -4.63303 | 14.5971 | 1.536 | 1.28 | -12.5 | -3.90625 | 11.328125 | |
47.66971 | 13.7254902 | 1031.25 | 14 | 0 | 14.00603 | 0.156 | 32.4 | -5.21344 | 14.5971 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.328125 | |
47.7397 | 13.7254902 | 1093.75 | 6 | 0 | 14.00603 | 0.117 | 32.4 | -4.8265 | 14.5971 | 1.536 | 1.4 | -12.5 | -3.90625 | 11.5234375 | |
47.81195 | 13.7254902 | 1031.25 | 7 | 0 | 14.07936 | 0.195 | 31.2 | -5.40691 | 14.7147 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.71875 | |
47.88171 | 13.7254902 | 1031.25 | 13 | 0 | 13.9327 | 0.1365 | 32.4 | -5.01997 | 14.7147 | 1.536 | 1.4 | -12.5 | -3.90625 | 11.71875 | |
47.95181 | 13.7254902 | 1093.75 | 6 | 0 | 14.00603 | 0.117 | 31.2 | -5.40691 | 14.8617 | 1.536 | 1.44 | -12.5 | -3.90625 | 11.9140625 | |
48.02174 | 13.7254902 | 1093.75 | 4 | 0 | 14.00603 | 0.1755 | 31.2 | -5.01997 | 14.8617 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.109375 | |
48.0917 | 13.7254902 | 1031.25 | 13 | 0 | 14.00603 | 0.156 | 31.2 | -5.21344 | 14.8323 | 1.536 | 1.36 | -12.5 | -3.90625 | 12.109375 | |
48.1607 | 13.7254902 | 1093.75 | 10 | 0 | 14.00603 | 0.195 | 31.2 | -5.21344 | 14.8323 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.109375 | |
48.23391 | 13.7254902 | 1062.5 | 8 | 0 | 14.00603 | 0.156 | 31.2 | -5.40691 | 14.8323 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.9140625 | |
48.30392 | 13.7254902 | 1031.25 | 14 | 0 | 13.85937 | 0.1365 | 32.4 | -4.8265 | 14.5383 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.9140625 | |
48.37373 | 13.7254902 | 1093.75 | 8 | 0 | 14.00603 | 0.117 | 31.2 | -5.79385 | 14.5383 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.71875 | |
48.44372 | 13.7254902 | 1062.5 | 9 | 0 | 14.00603 | 0.1365 | 31.2 | -4.8265 | 15.0822 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.71875 | |
48.51271 | 13.7254902 | 1000 | 15 | 0 | 14.07936 | 0.156 | 32.4 | -5.21344 | 15.0822 | 1.536 | 1.28 | -12.5 | -3.90625 | 11.71875 | |
48.58572 | 13.7254902 | 1031.25 | 13 | 0 | 14.00603 | 0.117 | 32.4 | -5.60038 | 15.0528 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.328125 | |
48.65772 | 13.7254902 | 1062.5 | 8 | 0 | 13.85937 | 0.156 | 32.4 | -5.01997 | 15.0528 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.5234375 | |
48.72772 | 13.7254902 | 1000 | 12 | 0 | 14.00603 | 0.1755 | 32.4 | -5.40691 | 15.0528 | 1.536 | 1.28 | -12.5 | -3.90625 | 11.328125 | |
48.79774 | 13.7254902 | 1000 | 15 | 0 | 13.9327 | 0.0975 | 32.4 | -5.01997 | 14.7882 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.328125 | |
48.8677 | 13.7254902 | 1062.5 | 6 | 0 | 14.07936 | 0.351 | 32.4 | -5.21344 | 14.7882 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.1328125 | |
48.93772 | 13.7254902 | 1031.25 | 8 | 0 | 14.00603 | 0.156 | 32.4 | -5.40691 | 14.6853 | 1.536 | 1.28 | -12.5 | -3.90625 | 11.1328125 | |
49.00771 | 13.7254902 | 1000 | 14 | 0 | 14.00603 | 0.1365 | 32.4 | -4.63303 | 14.6853 | 1.536 | 1.32 | -12.5 | -3.90625 | 10.9375 | |
49.07771 | 13.7254902 | 1062.5 | 7 | 0 | 13.9327 | 0.429 | 32.4 | -5.40691 | 14.3031 | 1.536 | 1.36 | -12.5 | -3.90625 | 10.9375 | |
49.14769 | 13.7254902 | 1031.25 | 7 | 0 | 13.85937 | 0.0975 | 32.4 | -4.8265 | 14.3031 | 1.536 | 1.28 | -12.5 | -3.90625 | 10.7421875 | |
49.21723 | 13.7254902 | 1000 | 13 | 0 | 13.85937 | 0.0585 | 33.6 | -4.8265 | 14.3031 | 1.536 | 1.32 | -12.5 | -3.90625 | 10.7421875 | |
49.28688 | 13.7254902 | 1031.25 | 9 | 0 | 14.00603 | 0.234 | 33.6 | -5.40691 | 13.9062 | 1.536 | 1.32 | -12.5 | -3.90625 | 10.546875 | |
49.35673 | 13.7254902 | 1031.25 | 9 | 0 | 14.00603 | 0.117 | 32.4 | -4.63303 | 13.9062 | 1.536 | 1.32 | -12.5 | -3.90625 | 10.7421875 | |
49.42671 | 13.7254902 | 1000 | 13 | 0 | 14.07936 | 0.234 | 33.6 | -5.01997 | 14.5089 | 1.536 | 1.28 | -12.5 | -3.90625 | 10.7421875 | |
49.49672 | 13.7254902 | 1000 | 13 | 0 | 13.85937 | 0.117 | 33.6 | -5.40691 | 14.5089 | 1.536 | 1.28 | -12.5 | -3.90625 | 10.546875 | |
49.56895 | 13.7254902 | 1000 | 11 | 0 | 13.85937 | 0.312 | 33.6 | -4.63303 | 14.6412 | 1.536 | 1.28 | -12.5 | -3.90625 | 10.546875 | |
49.63871 | 13.7254902 | 968.75 | 14 | 0 | 14.07936 | 0.117 | 34.8 | -4.8265 | 14.6412 | 1.536 | 1.28 | -12.5 | -3.90625 | 10.3515625 | |
49.7087 | 13.7254902 | 1000 | 12 | 0 | 14.07936 | 0.156 | 33.6 | -5.21344 | 14.6412 | 1.536 | 1.28 | -12.5 | -3.90625 | 10.3515625 | |
49.77873 | 13.7254902 | 1000 | 9 | 0 | 13.9327 | 0.2145 | 33.6 | -4.63303 | 13.7298 | 1.536 | 1.2 | -12.5 | -3.90625 | 10.15625 | |
49.84872 | 13.7254902 | 937.5 | 16 | 0 | 13.9327 | 0.117 | 34.8 | -4.24609 | 13.7298 | 1.536 | 1.24 | -12.5 | -3.90625 | 10.15625 | |
49.9187 | 13.7254902 | 1000 | 11 | 0 | 14.00603 | 0.1365 | 34.8 | -4.8265 | 14.7882 | 1.536 | 1.32 | -12.5 | -3.90625 | 9.9609375 | |
49.98871 | 13.7254902 | 1031.25 | 4 | 0 | 13.85937 | 0.0975 | 33.6 | -5.01997 | 14.7882 | 1.536 | 1.28 | -12.5 | -3.90625 | 9.9609375 | |
50.05874 | 13.7254902 | 968.75 | 12 | 0 | 14.00603 | 0.234 | 34.8 | -4.24609 | 14.7735 | 1.536 | 1.2 | -12.5 | -3.90625 | 10.15625 | |
50.12872 | 13.7254902 | 1000 | 15 | 0 | 14.07936 | 0.2145 | 34.8 | -4.8265 | 14.7735 | 1.536 | 1.32 | -12.5 | -3.90625 | 10.3515625 | |
50.20071 | 13.7254902 | 1062.5 | 5 | 0 | 14.00603 | 0.117 | 32.4 | -5.01997 | 14.7735 | 1.536 | 1.32 | -12.5 | -3.90625 | 10.3515625 | |
50.27075 | 13.7254902 | 1000 | 7 | 0 | 14.00603 | 0.234 | 33.6 | -5.01997 | 14.7 | 1.536 | 1.24 | -12.5 | -3.90625 | 10.546875 | |
50.3407 | 13.7254902 | 968.75 | 14 | 0 | 14.00603 | 0.156 | 33.6 | -4.8265 | 14.7 | 1.536 | 1.28 | -12.5 | -3.90625 | 10.7421875 | |
50.41104 | 13.7254902 | 1031.25 | 9 | 0 | 13.9327 | 0.4485 | 32.4 | -5.01997 | 14.5383 | 1.536 | 1.4 | -12.5 | -3.90625 | 10.7421875 | |
50.4827 | 13.7254902 | 1062.5 | 2 | 0 | 14.00603 | 0.156 | 32.4 | -5.21344 | 14.5383 | 1.536 | 1.32 | -12.5 | -3.90625 | 10.9375 | |
50.5527 | 13.7254902 | 1000 | 9 | 0 | 14.00603 | 0.1365 | 32.4 | -4.43956 | 14.6265 | 1.536 | 1.32 | -12.5 | -3.90625 | 10.9375 | |
50.6227 | 13.7254902 | 1062.5 | 9 | 0 | 14.00603 | 0.312 | 32.4 | -5.40691 | 14.6265 | 1.536 | 1.4 | -12.5 | -3.90625 | 11.1328125 | |
50.69269 | 13.7254902 | 1093.75 | 3 | 0 | 13.85937 | 0.1365 | 32.4 | -4.63303 | 14.6265 | 1.536 | 1.32 | -12.5 | -3.90625 | 11.328125 | |
50.76273 | 13.7254902 | 1000 | 11 | 0 | 14.00603 | 0.117 | 33.6 | -5.01997 | 14.9352 | 1.536 | 1.28 | -12.5 | -3.90625 | 11.5234375 | |
50.83282 | 13.7254902 | 1031.25 | 14 | 0 | 13.9327 | 0.1365 | 32.4 | -4.8265 | 14.9352 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.5234375 | |
50.90279 | 13.7254902 | 1093.75 | 4 | 0 | 14.07936 | 0.156 | 32.4 | -5.40691 | 15.0381 | 1.536 | 1.36 | -12.5 | -3.90625 | 11.71875 | |
50.9717 | 13.7254902 | 1031.25 | 9 | 0 | 14.00603 | 0.2145 | 33.6 | -5.21344 | 15.0381 | 1.536 | 1.28 | -12.5 | -3.90625 | 11.71875 | |
51.04172 | 13.7254902 | 1031.25 | 15 | 0 | 13.9327 | 0.117 | 32.4 | -5.01997 | 15.2733 | 1.536 | 1.4 | -12.5 | -3.90625 | 11.9140625 | |
51.11172 | 13.7254902 | 1093.75 | 6 | 0 | 13.9327 | 0.117 | 32.4 | -5.40691 | 15.2733 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.109375 | |
51.18175 | 13.7254902 | 1062.5 | 7 | 0 | 13.9327 | 0.1755 | 32.4 | -4.8265 | 15.2733 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.109375 | |
51.25231 | 13.7254902 | 1031.25 | 14 | 0 | 14.00603 | 0.156 | 32.4 | -5.60038 | 15.3909 | 1.536 | 1.36 | -12.5 | -3.90625 | 12.3046875 | |
51.32174 | 13.7254902 | 1125 | 7 | 0 | 14.00603 | 0.3705 | 31.2 | -5.01997 | 15.3909 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.5 | |
51.39173 | 13.7254902 | 1062.5 | 6 | 0 | 13.9327 | 0.156 | 31.2 | -5.60038 | 15.4938 | 1.536 | 1.32 | -12.5 | -3.90625 | 12.5 | |
51.46169 | 13.7254902 | 1031.25 | 13 | 0 | 14.00603 | 0.156 | 32.4 | -4.8265 | 15.4938 | 1.536 | 1.4 | -12.5 | -3.90625 | 12.6953125 |
I checked to see that it was enabled and i believe that it is.
I do however have the old school anti fouler trick on there still from before the patches came out.
I never had an issue with them and no P0420 or whatever the code was. Still holding up with the test pipe as well.
What type of intake setup do you have, hard pipe?
Try logging "air flow hz" at idle and see where you're at, maybe you're idling too high and out of the hz range for the ltft low to adjust...I can't remember what it is from factory, let me dig it up.
ecktt
May 8, 2017 06:18 PM
Raceghost
Jun 1, 2016 12:30 AM
