EvoScan MMCFlash ECU Reflashing Software
#61
At present I only own an evo 8 with autronic. However, I have been actively searching for a 91-97 mitsubishi eclipse gsx/eagle talon tsi awd again in decent or rebuild-able condition. I'll drop you a pm when I get something in hand.
However, if it's something you want to possibly pursue in a faster timeframe, there are plenty of dsm enthusiasts who would jump at the prospect of great tunability without having to go standalone.
#62
#65
VGergo please don't post information on this thread, it could be misleading, you make it sound like the Outlander Turbo has MH8302F, but you really meant you tried to make MH8202F work under MH8302F option in mmcflash, which of course was not designed for MH8202F.
For others.. yes MMCflash supports MH8302F currently.
For others... yes Outlander Turbo is MH8202F
MMCFlash support for Outlander turbo (MH8202F) is coming soon. PM me if you have a spare MH8202F ecu you can loan me for 4 weeks to make it work.
MMCFlash already supports the following ecus and more...
MH8301F
MH8302F
MH8303F
MH8304F
MH8301F
MH8302F
MH8303F
MH8304F
any chances of making a logger for Outlander turbo? We used MMCFlasher for reading and writing the stock maps ( after modifying) but we cannot find any solution for running a log...
#67
Hi,
do MMCFlash supports MH8105F?
I want to reflashing a Smart ForFour Brabus. The engine is 4g15t (the same as in the Colt CZT).
What version of MMCFlash do I need and wich kind of Reflashing Cable.
At the moment there is not the stock Flash at the ECU (Brabus 177hp). It a Flashware from a tuner with (210hp). But I exchange some engine parts and the fuel mixture is not good yet. So I hope that I can change the fuel trimm...?
Thank you for your support.
#68
For all those that have been asking every week...
MMCFlash reprogramming software is now back in stock.
Performance Vehicle PC Diagnostic Interfaces
Reflashing your 2006-2011 4G Eclipse Eclipse4G GT/GS/Spyder ECU
Reflashing 2006-2011 4G Eclipse Eclipse4G GT/GS/Spyder
#70
Hello!
I had to buy MMCFlash USB module 3 in EvoScan Web site.
I put the USB module plugged in my NoteBook.
The USB module has normal link, but I can not find USB drive in my
Explorer?
Is this normal?
Second, Is it must to install MMCFlash Software first?
But I can not find the download site. Or MMCFlash USB module 3 has
attached.
Later, I refer to technical manuals link on the operation:
Reflashing 2006-2011 4G Eclipse Eclipse4G GT / GS / Spyder
http://www.evoscan.com/technical-veh...e-gt-gs-spyder
Read ROM:
step1. plug in openport 2.0 cable.
step2. plug in MMCFlash USB dongle
step3. select "MH8104F [512K] can" (2nd option from the bottom)
step4. press Read
I thought it might have to actually plug in car, then it can work.
I follow the step 1 plug in openport 2.0 cable.
Then I plug in the MMCFlash USB dongle.
I think that MMCFlash Software will run automatically.
But the computer still does not have any action, can not continue to the
next step.
Please tell me the detail step how to use USB?
My operating system is windows 7, firewall, anti-virus is turned off.
Thank you!
Explorer?
Is this normal?
attached.
Read ROM:
step4. press Read
next step.
Thank you!
#71
Explorer?
Is this normal?
attached.
Read ROM:
step4. press Read
next step.
Thank you!
#73
#74
Hello!
Explorer?
Is this normal?
attached.
Read ROM:
step4. press Read
next step.
Thank you!
Explorer?
Is this normal?
attached.
Read ROM:
step4. press Read
next step.
Thank you!
You need to start the MMCFlash software after plugging in the Openport 2
Did you install the three components of MMCFlash BEFORE plugging in the usb ?
If not uninstall ALL MMCFlash components and re-install following the directions in the email, it should state to install all components and then plug in the usb which will self register. Once this is done you can open MMCFlash and on the bottom line will show your licence number.
MMCFlash will not start automatically, you need to start it manually, then you can select your ECU chip and press read.
In order......
1 plugin openport 2 to vehicle and laptop (vehicle ignition off)
2 Start MMCFlash software
3 plug in usb
4 confirm the usb is recognized ( bottom of the MMCFlash window displays licence no.)
5 select ECU from the menu
6 turn ignition on, I always wait a few seconds, then....
7 press read
When read OK is displayed.....
8 turn ignition off
9 save the rom file to your laptop
10 now you can unplug the openport and remove the usb
Hope this helps
#75
Yes it is normal for the usb to not appear in explorer.
In order......
3 plug in usb
7 press read
8 turn ignition off
Hope this helps
In order......
3 plug in usb
7 press read
8 turn ignition off
Hope this helps
Thank you.
I'm missing this software MMCFlash
謝謝你
我缺少這軟件MMCFlash
