transferring ceddy mods
ive just got an evo 4 which i have put a 6 ECU into, ive changed the injectors etc, what id like to know is, i have a ralliart map with 'ceddy mods' on, is there anyway i can transfer it from the ralliart map to my standard 6 one?
shane
shane
no possible, you need copy your stock ignition maps and paste it on ceddy rom and upload the ceddy rom in your ECU, you also can scale your 510cc stock injectors in the ceddy rom. you can use the ecuflash to do that, you can open two ecuflash windows, one with stock e6 maps and other with ceddy mods open.
open inj scaling the edit map def then select inj size evo then save thats for std evo 5 on 560 cc injectors
im running 6 injectors, ecu and maf, using evo 8 pistons, rod bolts, exhaust and uprated fuel pump.
i just want to swap the tables over to my standard map
kinda missed my point? so that means i use the ceddy mods ROM and adjust my car to suit? what about all the tables that i dont have on my standard map? just leave them be and swap everything over that i can?
sebas-chan
Apr 25, 2018 06:03 AM
