Final consensus on SD for a daily driver?
#31
read this.. https://www.evolutionm.net/forums/ec...bles-baro.html targets more on elevation stuff. however i dont use that 3d stuff its buggier then the original 2d imo.
i never had a customer complain their sd tune went to crap when they went somewhere drive ability wise.. but just in general your WOT afr is going to change. that is what i meant.
there are baro tables on the rom for this as well as i noted.
your car shouldnt go from great to horrible tho in elevation changes as you kind of explained above.
i changed 3 sensors thinking maybe something failed. but being john was so far away i figured it was time to just go the distance and get something well proven.
#32
well it will go from ok to drastically horrible if it isnt setup right to begin with.. say you were tuned in a diff state and you were still not tuned good.. car was spiking 17-18's at take off.. barely making it ok for stop and go.. well you move to a diff area and now all the sudden you're at 20+ afr on take off and you cant even get the car to move because as your reving up to take off you sputter and stall out and the car chokes on itself..
now lets say you were tuned at that same area but the tune was set for say 13-14 at take off.. you probably would never experience any of that choke or sputter once you reached your area because it would go from say 13-14 to 17 or so..
see what im saying? what Aaron said is right.. it depends how its setup.. if its setup wrong from the beginning then any little thing is gonna throw it off and make it run like ****.
#34
It was about 50 degrees this morning and my car started up just fine. I didn't move it until 120 degrees, but she fired right up, idled around 2k for a few seconds, and slowly crept down to my target idle. I do have this nasty tip-in rich problem, which seems to be worse when the motor is cold, but i'm sure I can tune that out.
#36
You want temp swings?? I drove my car on SD the past 3 years, from temps around 120 degrees, all the way into the 30's last winter. Altitudes from 1,500' all the way to 8,000'.
Driving to MOD this summer, the car went from 1,500 feet, up through 4,500 feet, then back to sea level with ambient temps as high as 120, going down into the 70's. This was in a 3 hour time span, and the tune was rock solid.
#37
To me, SD seems like more of a headache than its worth. I even know one very knowledgeable evo owner that is switching back to MAF after trying SD. Maybe someday SD will be the standard in the evo community. But for now, it seems like the majority of sweetly running 4g63's are still MAF based.
Ask yourself if the juice is worth the squeeze.
#38
SD evolves.
Cars I tuned a year ago dont reflect what I did last month. Last month doesnt necessarily reflect today. We learn stuff every day and every time we do it so basing a dislike of SD on one car is kinda silly. It is evolving and is getting more and more stock everyday. The main thing is if you dont want it drive like anything other than stock dont mod it, its always better but its never gonna be stock. For reference my car which is probably one of the most extreme combos I can think of does drive like stock. Main reason its something I can refine and then pass on.
Aaron
Aaron
#39
Personally, I live in Cali and can go through a pretty good elevation change when i drive home to louisiana once or twice a year.
Until someone figures out how to incorporate an aftermarket baro into SD, I'm not sold on it. If I was planning on pushing over 500 hp on it since it's a DD... I would so to SD because the driveability would be worth it and I know haw to touch up a SD tune if it starts bucking around due to elevation.
In the early days, I would be 100% against it. These days, it's kinda a wash... In another year or two, I'm sure it will become the gold standard.
#40
You dont need an aftermarket Baro. The MAP sensor is your baro. If you wanted the baro to reset at every start you can do that now. We havent seen a need from sea level to 5,000 and GotWheelHop ran out to 8k so I think we are good.
Aaron
Aaron
#41
I've been seriously considering going to SD myself as I'm going to be retuning with a 3'' downpipe, o2 delete, and then double pumper/FIC1450s/E85. Just with a stock block I don't really see the intake restriction being an issue at that power level, and I recirculate my BOV anyway. I hear a lot of comments about how "smooth" SD tunes are, but my car drives like stock with MAF, so I can't really imagine it getting much better?
#42
the power gains are evident from a restrictive maf to a 3" intake no maf, there was a dyno test on this somewhere on here.
everyone has their opinion on what drives better. even the COP kit was said to perform better. although everyones opinion is different, to some it might be a huge difference, to others theres no change. i found that out after reading about spring rates,driveline bushings and motor mounts. cant trust what peoples opinions are, you can only take them for what its worth and try it yourself.
the only real way to know is if YOU the drive did not know about the change. then the next time you drive ur car and it feels different then that is proof to yourself that it has changed. otherwise your mind is set that there is "suppose" to be a change and you will force yourself to believe there is.
#45
BTW, now my 101 kpa setting is still 101 load.
