Basemap for Eov 8
Basemap for Eov 8
I am new to this forum and appreciate any help.
I purchased 2003 EVO 8 built in US, and it's using AEM EMS series 1, but AEM just died on me on freeway. Car was running fine till it just went dead.
I could sent the ECU to AEM and get it fixed but never know when it's gonna happen again, so I wanna change to stock ECU.
Is there anywhere I could get basemap and purchase one so tunner here(S.Korea) can start the car at least, and just adjust time and fuel on dyno?
here is my mod
SD, Turbotrix / DTM built 2.3 shorblock, GT35R with 0.82 backside, Milspec 200 cell HFC, HKS 280 Cams, EVC 6 20 psi at high, Mitsu 2.4 crank, Turbotrix race head, AEM 5 bar map sensor, AEM fuel rail, PTE 1000cc injectors, Aeromotive A1000 regulator, dual pump with 2 WB 255, 8 feed 6 Return, and PLX M-300 WB.
here is my mod
so the cars off aem now? if so i highly recommend removing the aem 5 bar and replacing it with a omnipower 4 bar map sensor.
other then that i will pm you in regards to a basemap your tuner can work off, but the thing is he is gonnna need to understand how to control AFR with the additional tables in the sd rom.
i have no idea what the tuners in your country know or there skill level, but confirm he can even work with the rom first.
pm'ing you tho.
also.. AEM doesnt just die when its setup right, so dont be so quick to blame that issue on AEM.
pm'ing you tho.
razorlab
5165
Aug 11, 2024 07:56 PM
EyeDreamt
70
Oct 24, 2013 01:43 PM
