Bigger turbos!!!! Lag VS Launch
I have a big problem to do a good launch with my new setup, I have some lag but just in the launch, after the launch the car is awesome, no lag between gears.
I opened the Thread to help me set a good launch, I see that there is another similar topic on the launch control and antilag but only see maps with stock turbos evos.
I would like to see the launch and main maps in large turbo setups, I hope that the guys that have larger turbos projects here in the forum do not be selfish with their success they have had on this topic and that they can share it with us.
In advance thanks very much
I was not entirely happy with the stock ecu launch control setup. I was never able to build enough boost to get a great launch. For what it's worth, on a 35r type setup, i was launching at 7300rpm.
Aaron
Aaron
Also keep in mind when you transition maps during launch you have to smooth that transition. Especially if your going from -10 to -15 deg block right into your positive timing on your regular ign map.
