Warm start issues resolved FINALLY!!!!
#31
Don't think I ever said that. When I first started running FIC1050s and was having warm start issues, Jens put a set on this injector stand and found a very small drop forming after a long period of time (can't remember how long, but something of the order of 15-45 minutes). He told me that he subsequently altered his injector prep process for the Delphi injectors to stop this from happening. I never followed up with another set (and instead switched to FIC1100s which are not a Delphi injector), so I don't have any experience with how well it was fixed.
#32
I was just being dramatic.
I apologize for throwing you in it.
I checked my fuel injectors today (FIC1050cc) and they are not leaking.
Soooooo back to the drawing board.
I am gonna order the fuel rail adapter from the dealership so I can hook up my fuel pressure tester. Hopefully its a bad regulator.
Also, I did some checks to the regulator with compressed air and here is what I found:
With the vacuum port disconnected, air will NOT flow thru the regulator.
with vacuum applied , air will flow thru it.
Does that seem normal? Should the regulator be completely closed with no vacuum/boost signal?
Your thoughts?
Your thoughts?
#34
1 Post
I've been running the FIC 1050s since April & I am just now having some cold start issues. Warm starts seem to be fine but I will be keeping my eye on this thread & checking some stuff out soon.
#35
I checked fuel pressure today.
36psi with vacuum applied.
45psi with vacuum removed.
That is within limits according to the Dealer service manual.
Also I pressure checked the injectors up to 90psi no leaks.
I am at a loss right now.
I am going to start checking the ignition system now.
I put new plugs in today. We will see if that helps.
Also the problem is slightly worse on E85 and slightly better on 93oct.
