Injector Maf Scaling Help
It seems to be fluctuating voltage normally. I was thinking it could be that, but the voltages arent static or anything. It might be worth a swap though. I have another one.
Also my wideband read 14.7 at idle.
A little update.
I finally decided to start messing with injector latency. I added .2 ms across all the values. and my trims seem to be normal. But is this proper? and is normal to have to add that much latency to stock injectors? I'm still new to this and i just want to make sure that what i'm doing is reasonable. Or if what i did could cause more issues.
silvertune
Feb 1, 2016 03:30 PM
EvoVan
Nov 5, 2015 05:28 AM
dontek
Jun 25, 2010 12:39 PM
