Logging GM IAT on SD wired to MAF harness
Old Feb 12, 2012, 09:30 PM
211Ratsbud's Avatar
Originally Posted by donner
Actually I used wrongly stock mitsi scaling, I was on company pc when did that and copied wrong scaling. Sorry mate!.
No problem, the help was better than no help, and getting the sensor straightened out was the main objective.. I will switch back to the orignal if I get that back to GM iat instead of fuel temp.
Old Feb 12, 2012, 09:31 PM
Dynotech Tuning's Avatar
So Donner, is he correct about the MUT address and formula for the GM IAT wired to the MAF plug?
-Jamie
Old Feb 12, 2012, 09:32 PM
211Ratsbud's Avatar
Originally Posted by Dynotech Tuning
So I'm not crazy...whew! Thanks for looking Donner.
-Jamie
actually, scratch that. 1.43 would be handy to have for the scroll bar in those maps!
Old Feb 12, 2012, 09:45 PM
donner's Avatar
-Jamie
MUT11 after you have setted correct GM sensor scaling. Then just use normal formula what ever you like (ie. x-40 for C). MUT3A seems to be analog input RAM address and it seems evoscan calculates temp based on that so this cannot be used if sensor is not stock.
Old Feb 13, 2012, 04:58 AM
Isn't the formula for Fahrenheit at MUT11 x*1.8-40?
-Jamie
Old Feb 13, 2012, 05:04 AM
donner's Avatar
-Jamie
I believe it is, default formula at Evoscan. I use C so don't remember. But anyway, after setting good scaling you can log it with both formulas and it gives correct result.
Old Feb 13, 2012, 09:54 AM
donner's Avatar
Here is rom with scaling my friends been using for GM sensor.
File Type: hex
Old Feb 13, 2012, 01:05 PM
211Ratsbud's Avatar
lol thats my rom from the other thread. Im confused now officially. I thought you said you used a mistaken mitsubishi scaling on the rom you posted in response to my uploaded rom to show you the IAT i was using.
Old Feb 13, 2012, 07:38 PM
donner's Avatar
Yeah used you rom as base In my opinion it's not the same, only volt scaling looks the same but temp values are not. And I'm using Celcius scaling.
On the right your original (it was the one from early sd2.0 rom IIRC and on the left some known GM). I will test this now with sensor to be 100% sure but don't have time for that until weekend
Old Feb 13, 2012, 09:19 PM
211Ratsbud's Avatar
Thats a drastic change. Does the actual temp matter as much as the delta?
03whitegsr
Oct 8, 2017 08:16 AM
95630706
Oct 8, 2017 08:12 AM
2winscroll
Feb 16, 2017 01:39 PM
domyz
May 2, 2012 05:02 PM
ajstefanacci
Nov 13, 2010 07:17 PM
Quick Reply: Logging GM IAT on SD wired to MAF harness
