Logging GM IAT on SD wired to MAF harness
Old Feb 12, 2012, 05:08 PM
Dynotech Tuning's Avatar
Ok, I never use the GM IAT on the SD patches, I prefer the fuel temp sensor personally. I am trying to help a friend via email figure out whether or not he has his SD setup properly with the GM IAT wired to the MAF plug.
He is running the phenem pre-patched 94171715 rom
IAT Sensor Option is set to 0x03
My question is what exactly is he supposed to be logging in evoscan with the GM IAT in this location?
MUT3A, MUT11, MUT09?
What eval formula is correct for whichever location?
I just wanna be certain that he is getting the proper readings.
Thanks fellas.
-Jamie
Old Feb 12, 2012, 05:37 PM
211Ratsbud's Avatar
I linked a thread in your last iat thread. All of this info is in that, i was aable to determine my iat sensor was bad and replaced it with a napa part.
Old Feb 12, 2012, 05:40 PM
211Ratsbud's Avatar
https://www.evolutionm.net/forums/sh...hlight=log+iat
Old Feb 12, 2012, 06:41 PM
I hate to tell you but the SD IAT scaling he gave you is the scaling for the stock MAF IAT sensor, unless I missed something. BTW, that thread is a mess with the exact details to which evoscan formula worked for you. Would you mind just telling me what you are using?
If anyone else can chime in as well, that would be helpful to see what others are using. Just to be certain.
Old Feb 12, 2012, 08:44 PM
211Ratsbud's Avatar
You missed something. Those guys were all aware of what was going on, the SD Spoolin up harness, gmiat, etc, they all realized tha and offered that the formula is the same as stock. This is what lead me to chase down a bad sensor, after not knowing wtf was going on with my car.. I had been tuning wtih a stagnet sensor for the whole summer and into winter!
Sorry for the scatter, but you need to use MUT11, since that is the parameter used for fueling, and eval is identical to stock coming in with 1.8*x-40 putting out *F.
Again, have him "check" before he even starts the car. That is the best way to line things up. There is different scaling for the same sensor floating around, I havent tested every one of them. I am going to go to the fuel temp as my temp in my own SD car for now.. However I will be logging IAT via uicp for other things.
Old Feb 12, 2012, 08:48 PM
Thanks. Have you compared the scaling Donnor posted for you to a stock 94170015 rom yet? It's identical from what I could see.
Old Feb 12, 2012, 08:51 PM
211Ratsbud's Avatar
No I havent. I really wish I could, but are you referencing the two roms that are in that thread? I did never go back to my original after Donner updated it. However, the original was the one pulled from the 3dSD thread which noted that all roms had updated scaling. So in summary, I have no damn clue!
Old Feb 12, 2012, 08:56 PM
211Ratsbud's Avatar
PS on a car you have setup with fuel temp used for SD IAT, do log mut11 and use the 1.8*x-40 and see how close a warmed up car is to ambient. I would think that mut11 would posess the temperature used for fueling no matter the origin. Ill be giving that a shot once I get back to my car running.
Old Feb 12, 2012, 09:12 PM
donner's Avatar
It should not be stock scaling, it is the one used in sd2.0 roms and is scaled for GM sensor. Anyway will take another look.
Old Feb 12, 2012, 09:16 PM
211Ratsbud's Avatar
By stock was he referring to the off the shelf scaling in that rom on an original 2dSD rom vs the off the shelf in 3dsd vs the one you updated for me in that original post... or atleast thats how I took it.
Old Feb 12, 2012, 09:25 PM
No, by stock I mean...stock IAT sensor in the MAF scaling. Like, same scaling as a MAF rom. I may be wrong but that's what it looked like to me.
The owner of the car cannot use the fuel temp sensor because his is no longer in the car. It has an aftermarket fuel system and doesn't utilize and stock fuel components or tank.
-Jamie
Old Feb 12, 2012, 09:27 PM
211Ratsbud's Avatar
Rodger that, are you using ECU flash 1.43 or 1.42?
Old Feb 12, 2012, 09:28 PM
donner's Avatar
Actually I used wrongly stock mitsi scaling, I was on company pc when did that and copied wrong scaling. Sorry mate!.
Old Feb 12, 2012, 09:29 PM
1.42
Old Feb 12, 2012, 09:30 PM
So I'm not crazy...whew! Thanks for looking Donner.
-Jamie
Quick Reply: Logging GM IAT on SD wired to MAF harness
