cant load tephra v7 in ecuflash directory
Old Mar 5, 2012, 11:57 AM
outtanowhere's Avatar
I dont know what I am doing wrong. Spent over 10 hours trying to figure out how to load teprha7 in my 94170008 rom. Whew mentally exhausting.Can someone explain. I read everything watched videos and nothing.I tried adding it directl but computer wont save to ecuflash under 94170008.I have it saved on my destop. Please help.
Old Mar 5, 2012, 12:44 PM
Boosted Tuning's Avatar
First, you dont "load" tephra7 into your current ROM.
You need a whole new ROM, in your case Tephra ROM 94170715. The ROM will come with definition files, that you load into your .xml directory. Then you can see all the tables and features of tephra.
Then you have to copy over your current tune on your original ROM to the tephra ROM and load it on your car.
Hopefully that helps.
Old Mar 5, 2012, 01:18 PM
understood. Can I use 96533706? I used the wrong choice of words.
Old Mar 5, 2012, 01:24 PM
You can but 94170715 is a better options, as your native ROM was also from the 9417 family. And your car is a USDM car and 94170715 is a USDM ROM.
9653 is a Euro ROM, that can take some tweaking to get perfect on a USDM car.
Old Mar 5, 2012, 01:48 PM
ok Iwant to do speed density so shouldnt it be 94173715? Just asking.Do I put it in romdata a little confused
Old Mar 5, 2012, 02:04 PM
Not understanding where in the xml directory to put it.I had no problem tuning the car prior to this.Want to use 2150 injectors andspeed density.Went from stock turbo to 35r,thanks.
Old Mar 5, 2012, 02:27 PM
Yes, use 94171715 for SD.
The .xml files goes here......
C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
Old Mar 5, 2012, 03:34 PM
ok good I got that far. Once I get it there what do I do with it then to run ecuflash. Thanks for helping me. I had to run out. Back now.Inever had these issues with my 800 hp 1st gen lol.
Benja
Jul 3, 2019 12:42 PM
noobers8
May 22, 2017 08:41 PM
R. Burgundy
Aug 18, 2015 05:37 PM
roger smith
Aug 31, 2009 10:07 PM
EvoPlaya31
May 14, 2009 09:40 PM
Quick Reply: cant load tephra v7 in ecuflash directory
