Severe Idle dips, HELP!!!
Ok wasn't able to check yesterday, had a guy come over for some work on his durango after I got out of class. Anyhow so I checked today and confirmed crank sensor is not the issue . Which I guess can be good and bad. Spark checker confirmed that spark is not cut when these dips occur.
Not running your rom but ran into a posible issue for you to check out. I had a failing coolant temp sensor. Sometimes it would read properly sometimes not. Verfied this through logging of course. It would go from 189* to 100 irradicly and this would affect the idle. Replaced sensor all was good. Just an idea.
I dont recall any irradic coolant temp sensor readings when I was logging idle the other day but I am definitaly willing to give it a shot I'll post up and let you guys know what happens. Changed one of my couplers Saturday so I did another boost leak test but that came out fine.
For the sake of idle alone I put all my idle type settings and maf settings into my stock base lancer rom awhile back and the idle seemed rough but stable I didn't notice any dips, issue there is my stock rom is beyond limited for me to properly tune my car with the setup I am running now. I have tried 96530706 before and I honestly cant remember if the dips were there or not but I do remember throttle hang was horrible and I was not able to correct it so I promptly switched back. Any suggestions on roms to try? Mainly just need to have big maps and cel flash in them. Dont care about any of the other tephra options.
So I figured to bump this thread rather than start another. Any more ideas for me?. I have since been able to do a prolonged boost leak test and liberally sprayed soapy water while holding 15+ psi (since I run 15 currently), any small leaks I fixed so absolutely sure there are no boost leaks anywhere from the turbo to the combustion chambers. Can someone tell me if the egr disable works in tephra's V7 94170715? I read that the FAA periphery bit that was supposed to disable it actually does not, and there is another table labelled in this rom to disable it.
Still have the dips :-(. I have installed a new maf, swapped map, swapped IAC, swapped EGR, Swapped the solenoids connected to the vacuum lines bolted to the IM, swapped and completely cleaned the IM itself, cleaned everything that I have swapped, cleaned throttle body, new plugs gapped correctly. Not sure if I mentioned that if I let it sit idling like this for awhile I will eventually get a random multiple cylinder misfire code, I have gotten it 3x and only after prolonged (like 30 mins or so) of idling. I have not swapped coil packs but I do not believe it is them, one reason is because the spark plugs are firing when dips occur and two the idle never dips when cold and I get no misfires while driving.
I'm having a very similar issue with my rebuilt 4g69 eclipse. first start up was great even warmed up, second start up it started to stumble a bit. by time the first test drive was done, warmed up it wanted to stall (and sometimes did) at every stop sign. It has progressively gotten worse over the past couple days. Now occasionally stalls when cold, and almost always when hot.
throwing p0300. Hadn't had a chance to check anything, car is parked until saturday. any more updates on this?
here are my two vids
I believe list of new and old mods are in that first vid.
i too have this same problem. basically exact same setup you have. dips or dies after reving or pulliing it out of gear and goes super rich. i have done nearly everything you have done. but mine has been like this since i went turbo and it is so frustrating.
i know this thread is old but it has yet to be solved
My car has no other symptoms except the dips. I have however managed to greatly decrease the dipping. I noticed my timing at idle was way higher than I thought it would be. I adjusted the timing down a few degrees and that made a dramatic improvement. I havent messed with it since my initial timing change so I still have them a little. I fully expect when I get some time I will be able to adjust the timing more and get rid of my dips completely
