check engine light help!
hi i have 2 cel's coming on right now since i converted to v7, but i dont know what they mean!
P1400 Manifold Differential Pressure (MDP) Sensor Circuit Malfunction
P0183 Fuel tank temperature sensor circuit high input
can you guys please help me by explaining to me what the above cel's mean...
before the convert there were no cel's..
I'm not really sure, but this is what I would do. Flash back to your old rom and see if they go away. If the do, confirm that the tephra rom you are using is the correct version for your car, if it is, try reloading the tephra rom. I have experienced a CEL when loading a new rom that went away by reloading it. Also you my try posting in the Tephramod V7 thread with this question as well.
It sounds like you either loaded the wrong rom or your scalings for those sensors are off. What MAP sensor are you using ?
and by the way the car drives fine and several times ive just cleared the DTC's from evoscan but as soon as i turn off the car and turn it back on the cel's come on...
im wondering if i just disable them will it be okay? cause like i said the car drives fine even with the cel's on..
and im not on MAP im on a MAF,if thats what you asked.
evohq
Feb 21, 2016 06:49 AM
EvoSeanzie
Jun 20, 2010 06:18 PM
BadazzCR
Aug 23, 2008 07:40 AM
