Super Rich when Immediate Full Throttle.
Hi,
can someone share on how to improve my Throttle Response as whenever i Full Throttle my car AFR deeps richly (10~10.3 AFR) and ive to immediately go partial throttle and wot again only than my car accelerate.
Some may say its a Lazy Spool aka Lag but can this be improve on the tune?
My turbo start to charged at 2,800rpm and full boost abt 4,300rpm
1) Can i adjust on the Accel Enrichment?
2) Will it effect the tuned Fuel Map after the adjustment?
3) Should i lower the % or higher the % on the Accel Enrichment?
4) Is there any other adjustment that i need to make after the adjustment?
My Spec's :
2.0L
GT3076R
S2 Cams
85.5mm Pistons
Sard 850cc injectors
Thanks
My Spec's :
2.0L
GT3076R
S2 Cams
85.5mm Pistons
Thanks
Did you sort your injectors and main map fueling out yet James?
I wouldn't go touching the 'fine tuning' parts of a rom such as the "accell enrich" until the main coarse areas are sorted.
I've never had to modify the accell enrich table once the injectors and main fuel maps are dialed in correctly.
will re-check the final scale, latency vs the fuel map and will update here again.
Thanks
Hi MrFred,
im using the latest Synapse Bov and the plumb back have resolved my staling problem.
There is only 1 remaining problem which i really hope to improve or solve.
Here is the link about my problem and really hope someone can help me end my nightmare...
https://www.evolutionm.net/forums/ec...l#post10300926
Slo_crx1
Apr 3, 2008 03:57 AM
