Trouble Logging 2010 GSR With EvoScan. HELP!
Hey guys,
I've been trying to log my 2010 GSR with EvoScan and a Tactric 2.0 cable, but can't seem to get it to work properly.
I've tried using all of the mode 23 info in the sticky posted here, as well as searching through countless threads on here and the EvoX forum with no luck. I've used the GoldenEvo XML files and "Select ECUs" in EvoScan as well, and had no luck with any of that.
I've gone as far as throwing a stock tune in there (ROM ID: 55570005) and copying my old timing/fuel maps over it and still had no luck. I've tried the mode 23 modifications 3x and had my buddy double-check the work, and it makes no difference.
The most luck I've had so far is: I can log most items using "CAN OBDII", but I have no option to log Knock Sum, Knock Voltage, etc... and the request IDs are very vague compared to other logging methods. When I try other logging methods in EvoScan, I get some values to show, they aren't all correct, and most values don't show at all.
Can someone please help! I've been trying to tackle this problem for days with no avail! Thanks in advance!!!!
Just wanted to update this thread for the OP. We were able to get the car to start logging. We tried all of the above suggeststions and it failed to work the first couple of times. We then switched to my laptop, and were able to get the car to log. Odd problem, but think it may have been PC related - though we failed initially with my PC too...
We are now logging successfully however, minus a couple small discreprencies in some of the values we are trying to log. They are known issues though with fixes we just need to address. Thanks guys.
somedood451
Lancer Engine Management / Tuning Forums
Jun 13, 2012 08:47 PM
