How to Add Load Cell?
Hi,
can someone share on how to add load cell X & Y axis in a proper way?
i know how to add load cell but no matter how i smooth it out the timing, afr & low timing or octane maps will varies from the adjusted high octane or timing maps.
When i smoothen the low timing & fuel maps, the high octane maps figure runs.
How to solve it.
Thanks
How to solve it.
Thanks
If I understand what you're going for, adjusting the scaling on one map adjusts them all because they all rely upon the same load address inside the rom. If you scale High Octane, it will automatically scale Low Octane to the same. You can't adjust the scaling differently for different maps.
