Grimmspeed 3 port ebcs, need help
Old Nov 5, 2012 | 04:00 PM
skaterdude888's Avatar
Today I replaced my stock boost solenoid with the Grimmspeed 3 port ebcs. after setting my WGDC to 50 across the board, I took it out for a test drive. Everything seems to be working fine other than the fact that I'm hitting only a max of 7psi. Previously I was hitting a max of 9psi on the stock solenoid, which lead me to think that it was dead.
I've zeroed out the Boost Error correction, and have increased the WGDC to 70, still with nothing over 7psi...
I'm 99% sure I hooked up all the vacuum lines correctly, as per their diagram so I imagine my problem doesn't stem from that. Has anyone else had a similar problem? Any one have any ideas.
thanks
-Steve
Old Nov 5, 2012 | 04:26 PM
[IMG][/IMG]
Don't know if this helps, but this is what I've got going on so far..
Old Nov 7, 2012 | 11:04 AM
DNBishop's Avatar
Your boost limit rpm looks jacked.
Old Nov 7, 2012 | 11:15 AM
211Ratsbud's Avatar
Yea a scaling or part of the XML is missing.
Post your rom ID
Old Nov 7, 2012 | 01:02 PM
dolphin888's Avatar
Post your rom ID
His ROM ID is 94170015 and scaling or part of xml is not missing, it's just incorrect. There is a bug in Ecuflash. He needs to change RPM adress to 6dd2, as written in this topic:
https://www.evolutionm.net/forums/ec...4170015-a.html
Old Nov 7, 2012 | 01:08 PM
dolphin888's Avatar
Yes, it helps. There are few things you need to try:
1) Increase your boost control load offset from 60% to 100%.
2) Set boost desired engine load to 159.4% (max) across all RPM range
3) Make a test drive, if needed adjust max wastegate duty.
Old Nov 8, 2012 | 10:18 AM
Boosted Tuning's Avatar
This is NOT how you setup ECU boost.
And OP, I answer your question in the other thread. Here it is again.
You most likely have a mechanical problem.
On the stock solenoid you should have hit 16-19. Even on just the stock wastegate you should hit 11-13.
You may have a blown turbo or major exhaust leak or something.
Old Nov 8, 2012 | 10:36 AM
dolphin888's Avatar
This is how I setup MAC 3 port solenoid ECU controlled boost. It works.
Old Nov 8, 2012 | 10:51 AM
dolphin888's Avatar
Although I agree he should check for a boost leak.
Old Nov 8, 2012 | 10:56 AM
It may "work" but thats not how to CORRECTLY setup ECU boost. I know, I wrote the how-to's on ECU boost. Plus i have tuned ones of cars on ECU Boost.
Old Nov 8, 2012 | 11:09 AM
dolphin888's Avatar
As long as it works for me and other guys it's correct for me. Works = correct.
Old Nov 8, 2012 | 11:13 AM
dolphin888's Avatar
This how to is really helpful (from page 88):
http://www.evoscan.com/ecuflash/Merl...UIDE-V1.7a.pdf
Old Nov 9, 2012 | 06:28 AM
Thanks for the replies guys! I corrected the RPM on the boost limit table, Just need to find some time to mess around with it all.
Boosted tuning, I did see the other post. Thanks, Its kind of my fear that the turbo is going.
A little more background on the boost. When I first bought the car (about 2 years ago) it was pressing about 18psi. About half a year or so ago it stepped down to 13psi, and now recently 9psi until I changed out the stock solenoid and now I'm hitting 7-8psi. I did a bit of research and did find that on the wastegate I should be hitting around 11psi so that's where I had thought it could be the bcs.
I'll have to do a boost leak check at some point, But i'm also starting to think its the turbo. Unfortunately, that's not exactly in the budget
Old Nov 9, 2012 | 09:04 AM
Its not the correct way to setup ECU boost. Im not gonna sit here and argue with you, so you can think whatever you want, but your doing it WRONG.
Old Nov 9, 2012 | 04:27 PM
dolphin888's Avatar
You too. Thank's.
Quick Reply: Grimmspeed 3 port ebcs, need help
