I'm confused with read/write and tephra v7 mod!!
Hello guys. I have some questions because i cant find the answer anywhere and now i'm confused and i need a help!!!
Firtsly, some infos about my car (evo 9 - rom 88840017). My car is reflashed from another tuner and he put tephra v7 to my car.
I start to do some logs and i saw too many knocks and i create some now maps a little more rich with less ignition timing.
So now i have some question.
1)when i read my rom i read a hex file only(or and xml file)?
2)when i read my rom i cant see tephra mods!
3)i want to write back my new hex file. So if i write back my hex file, i will lost my
tephra mods?
4)when i will write my hex file back to my car,i am also writing and the xml file(stock with no tephra) from ecuflash?
5)how i can read my tephra mods with ecuflash or evoscan?(i dont have his tephra
xml file)
6)which program is right to write back my new tune hex file and keep my tephra mods (ecuflash or evoscan)?
Thank you for your time.
And i hope someone to help me because i want to write back my file today!
tephra mods?
xml file)
If you read my question you will see that I want to write a new hex file and keep the tephra, how I can read my tephra setting from my tuner,...?
Thanks guys for the time!
now i open the hex file with the original xml file!
xml files are saved to rommetdata in ecuflash
if you look in your laptop my computer/C;/ program files/ open ecu/ecuflash/ rommetdata /evo you will see all the xml files you have , when you download ecuflash it already has some xml files in there but not the v7 or modified ones.
its in here
http://api.viglink.com/api/click?for...13562892672044
download and open then save the xml second one down to my computer/ C; / program files/ open ecu/ecuflash/ rommetdata /evo
