Immobilizer (again)
Old Jan 18, 2013, 06:27 PM
nuk1ear's Avatar
Immobilizer (again)
Hi all,
I got ecuflash (1.42) and downloaded the latest version of tephra v7 stock (mods but not speed density etc, the one suggested here https://www.evolutionm.net/forums/ec...hramod-v7.html)
I used EDM/JDM/USDM 96530006 As i have a JDM evo 8.
Before i did anything i read, saved and wrote down my immob codes multiple places. Saved the stock rom etc.
Now i entered my correct immobilizer code, but there is no HEX viewable in my stock read rom. I added the following line to the evo7base.XML (which ecuflash says it is reading for my stock rom)
Code:
<table name="Immobilizer Hex" category="Misc" address="ffa" type="1D" level="2" scaling="Hex16"/>
I then open the rom but i cannot view the damn IMMOB HEX code. Why? I know its the immobiliser stopping my car from starting because if i disable it bit 2 in the pref codes the car starts fine lol.
Any ideas?
Old Jan 19, 2013, 09:55 AM
todd6027's Avatar
put the xml included in 96530706 tephramod v7 zip into your evo rommetdata ,thats what the new rom 96530706 needs to be viewed correctly , the immo and immo hex is in that , it no longer will be uses the 96530006 or evo7 base xml to open the new rom
Old Jan 20, 2013, 04:25 AM
nuk1ear's Avatar
sorry i dont exactly understand what ur saying mate.
I downloaded the tephra mod set and put them in that folder. But my STOCK ROM which i downloaded from my car does not show IMMOB HEX when i open it.
Old Jan 20, 2013, 09:53 AM
todd6027's Avatar
can you see the immo number in the stock rom , if its immo hex ffa you mean then it doesnt apply to the stock rom only the v7 one . here what you set it too also you need to enter it as 0xXXXX , or click the box hit enter in the box type 0x then the appropriate number and hit enter. (0 is Zero not O)
0x0040 for 2003 or 0x0055 for 2004 or 0x0058 for 2005 USDM - 0x004D for EDM:
Old Jan 20, 2013, 03:45 PM
nuk1ear's Avatar
Thank agains,
I have the Immobiliser number from the stock rom. But I thought you need to also enter the correct code for IMMOBILISER HEX into the V7 rom. Is this wrong? If you open Immobiliser Hex, it says "for 2003 enter XXXX, 2004 XXXX, 2005 XXXX USDM, for EDM enter XXXX". It doesnt say anything about JDM? I input the correct value for Immobiliser, but it wont let me start the car.
Then if i disable Immobiliser but making the prephery bit FFA bit 2 =0 it DOES start. Therefore, the issue is 100% immobiliser.
Old Jan 21, 2013, 02:05 AM
todd6027's Avatar
did you try 004D ??
Old Jan 21, 2013, 03:54 AM
nuk1ear's Avatar
ill give that a shot, but i think i did try to EDM one yeh. Its very weird, someone else has told me once that in the JDMs it doesnt seem to work right. but meh, ill give it another shot mate.
thanks again
Old Jan 21, 2013, 04:17 AM
todd6027's Avatar
yhpm
Old Jan 21, 2013, 10:24 PM
nuk1ear's Avatar
thanks mate, ill it when i get home tonight, flat out with work I dont have an AUS vehicle, mine is Japanese, just FYI (you mentioned to checked an AUS rom in the pm)
Old Jan 22, 2013, 03:04 AM
todd6027's Avatar
96530006 is an aus /sa rom iirc
Old Jan 22, 2013, 03:51 AM
nuk1ear's Avatar
sent it just now. let me know how you go man
Old Jan 22, 2013, 04:01 AM
todd6027's Avatar
e mail returned your original is 93660005 rom
Old Jan 22, 2013, 04:08 AM
nuk1ear's Avatar
thats what i used previously but the car wouldnt start :/
Old Jan 22, 2013, 04:10 AM
todd6027's Avatar
send me the new rom
Old Jan 22, 2013, 09:19 PM
nuk1ear's Avatar
ill try and send it to you tonight. But as i said, i disabled it in the rom im using atm, so there was no need to enter it. Its very clear where you enter it (MISC--> IMMOBILIZER and IMMOBILIZER HEX)
Quick Reply: Immobilizer (again)
