Evoscan not reading KnockSum?
Old Feb 6, 2013 | 08:46 AM
EvoIXPilot's Avatar
Just got evoscan and tactrix 1.3. It reads all "ticked" items except for knocksum and AEM WB, but that I'm still troubleshooting. Both of them show blank/0 the whole time I was logging. For knocksum, did I forget a configuration or setting on Evoscan?
Old Feb 6, 2013 | 10:21 AM
Raptord's Avatar
Nothing needs to be changed from the default evoscan config to log knocksum. Either you aren't knocking or the knock filters have been numbed down.
Old Feb 6, 2013 | 10:43 AM
211Ratsbud's Avatar
Blank is different than a zero.. Which is it?
Old Feb 6, 2013 | 12:16 PM
EvoIXPilot's Avatar
blank. The function cell has an "x" while the other function cells (boost, rpm, etc) has math formulas. This is the same for External Wideband. It as if the evoscan is not detecting a knock sensor. However, the Knock voltage is working.
Old Feb 7, 2013 | 12:46 AM
codgi's Avatar
Post a screenshot of your Evoscan settings and a log.
Old Feb 7, 2013 | 11:54 AM
EvoIXPilot's Avatar
I'll take a pic when I get home. But is it possible I have no knock at all? Wouldn't the value during live logging be '0' and not blank? Finally, is it possible that the previous owner changed ROM by ecuflash to disable knocksum?
More info, I contacted my tuner (not sure how/what he used to tune) but he said in order for them to tune, the knock had to be working or it goes in to limp mode. So I'm thinking, someone turned it off via ecuflash; I have a bad copy of evoscan; or I truely have no knock and it just shows blank??
Old Feb 7, 2013 | 11:55 AM
Raptord's Avatar
No knock reads 0, not blank.
Old Feb 7, 2013 | 11:47 PM
codgi's Avatar
This. Once we have the screenshot and the logs might be some other things I can think of.
Old Feb 8, 2013 | 06:01 AM
EvoIXPilot's Avatar
It does read "0". Then again, I don't have a external WB hooked up and it reads "0". That why I got confuse. I will still try to take a screenshot.
Mitsu.kid.02
Lancer Engine Management / Tuning Forums
217
May 25, 2016 11:47 AM
xaxasv6
May 29, 2015 02:27 AM
3VOLUTIONIST
Apr 24, 2015 10:52 PM
Lancer_Evo_8
Apr 26, 2013 05:47 AM
bsh
Dec 9, 2012 12:48 AM
Quick Reply: Evoscan not reading KnockSum?
