FIC 1650 idle and accel issues.
Added a Wally 450, AFPR, and 1650's last night and scaled the injectors to 1650 and input FIC's recommended latency numbers and the car idles like crap and wont budge from a 10.6-11.4 AFR at idle and will hardly rev at all.
I've tried scaling from both extremes from 1200-2400 for the hell of it with no change and went from modded stock-1550-1650 latency and no change as well.
Car is on pump gas and being updated with ECUFlash. Any Ideas?
Start with changing the injector scaling at around 1329. You need to search the forum for the additional tables for "minimum IPW" if you don't had them already. The factory setting is 1.280ms IPW and that's going to make the fuel rich at idle and it needs to be lowered.
Also make sure your AFPR is set to 43.5psi with the vacuum line disconnected from the AFPR while idling.
-Jamie
-Jamie
Ok, So I've been non stop searching on how to add ipw minimum and have tried adding it to my xml with no luck.. my xml is 94170008
Also I switched back to stock injectors and reset latency and scaling but now it won't idle under 2k with zero vacuum leaks..
Any help is greatly appreciated..
mrfred
Dec 27, 2016 09:26 PM
black E
Sep 22, 2014 10:42 AM
