how to tune Anti Lag Map ?
Hi uy, ,I'm tuning my own Evo 6 and there is
1. Boost Enhancement Enrich/Enlean ( Anti-lag ) Map
2. Boost Enhancement ( Anti-lag ) table
Im trying to tune it to be back fire when I shift or Let off gas pedal do you have any idea where I should adjust the map
- There is a Fuel Map table as a pic
- there is a voltage and RPM as pic
![](http://i296.photobucket.com/albums/mm167/pom_zookzon/IMG_6532_zps9946a307.jpg)
DO I need to adjust my Main Timing and fuel map in order to tune it to have back fire when i shift and let off gas ?
Need some help thank you
those tables are wrongly defined ,use the Als tables and timing retard table if they are defined in the rom if they are not post the rom id and il send em over just add to the xml
these are for 24430002
<scaling name="Timing Retard" units="units" toexpr="61-(90*x/256)" frexpr="(61-x)/90*256" format="%.0f" min="0" max="255" inc="1" storagetype="uint16" endian="big"/>
<table name="ALS minimum vehicle speed to trigger" category="ALS" address="11524" type="1D" level="1" scaling="VehicleSpeed"/>
<table name="ALS minimum coolant temperature to trigger" category="ALS" address="11526" type="1D" level="1" scaling="Temp"/>
<table name="ALS minimum RPM to trigger" category="ALS" address="11528" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="ALS minimum load to trigger" category="ALS" address="1152a" type="1D" level="1" scaling="Load16"/>
<table name="ALS minimum time to trigger" category="ALS" address="1152c" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS trigger valid time" category="ALS" address="1152e" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Load below which active" category="ALS" address="11530" type="1D" level="1" scaling="Load16"/>
<table name="ALS active time limit" category="ALS" address="11532" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before air injection" category="ALS" address="11534" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before fuel injection" category="ALS" address="11536" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Fuel injector time" category="ALS" address="11538" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Air injection time" category="ALS" address="128c8" type="2D" level="1" scaling="Timesecbyte">
<table name="RPM" address="2c83a" type="X Axis" elements="9" scaling="RPM"/>
Rallyman
Aug 24, 2009 10:03 PM
