Tuning Evo789 ACD
#213
No, increasing only the max pressure dosen't have any effects because the max current given to valves is always the same.
You can increase the acd throttle lockup adder at low speed. So, as default, the lockage power is increase even if there isn't any slipage.
#220
did it...
but now that i can tune the acd and ayc im not satisfied...i want my evo 8 to do the runabouts in style...but the front is always going out...i want the car to be almost like RWD....what can i do...
#221
Seriously, a rear sway bar and an upgraded rear diff is all you need for the car to rotate on demand (along with an higher power/grip ratio than stock)
#223
Hi, Im begining to work on my ACD/AYC, I own an JDM Evo 7 RS2. Running Tephra 90550001 V5.10 on the ECU.
I want to flash 6 mode ACD/AYC rom, but first want to read from ACD/AYC Ecu. I already made the Pin #25 connection to the 2.5mm jack on my openPort 2.
Already read the Rom from my car, but it seems that there are NO definitions (xml) to show the tables nor options.
I run the compare option on ecuflash with an suposed original acd/ayc rom, and there are no issues and has everything same exept two fields. I also tried the test flash, and there are no issues.
Can I run the original ACD map to my car with no issues?
The rom that i downloaded from my car is 129kb, same as the other maps.
Thanks.
PS: EvoScan is not recognizing my ACD/AYC actuators, what can it be?
------------------------------------------EDIT--------------------------------------------
[ATTACH]This is the ROM that came from my 7[/ATTACH]
Thanks.
#224
Thanks.
Thanks.
#225
