ECT Fuel Compensation definition (53040010)
Hi,
can someone check if this adress are correct for the ECT Fuel Compensation on 53040010 Rom please?
<table name="ECT Fuel Compensation #1" address="5ab31" category="Fuel" type="3D" level="2" swapxy="true" scaling="Percent128">
<table name="Load" address="61812" type="X Axis" elements="41" scaling="Load"/>
<table name="Coolant Temperature" address="61042" type="Y Axis" elements="9" scaling="Temp"/>
</table>
<table name="ECT Fuel Compensation #2" address="5aca9" category="Fuel" type="3D" level="2" swapxy="true" scaling="Percent128">
</table>
Best regards...
</table>
</table>
Best regards...
Askar (Sep 12, 2021)
Finaly, it was cold enough to test it.
It worked for "me".
14.7 AFR right after turning on the Ignition.
I set both table to 100%.
No problem with coldstart, as long as the ECT are higher than ~3°C.
Lower temps need higher (richer) values than 100%, otherwise the engine has trouble to start.
It worked for "me".
I think these addresses are correct for 56910009.(Caution: NOT TESTED.)
<table name="ECT Fuel Compensation #1" address="5ae0d" category="Fuel" type="3D" level="2" swapxy="true" scaling="Percent128">
<table name="Load" address="621d4" type="X Axis" elements="41" scaling="Load"/>
<table name="Coolant Temperature" address="618e8" type="Y Axis" elements="9" scaling="Temp"/>
</table>
<table name="ECT Fuel Compensation #2" address="5af85" category="Fuel" type="3D" level="2" swapxy="true" scaling="Percent128">
</table>
</table>
</table>
crimson red (Nov 23, 2019)
sebas-chan
Apr 25, 2018 06:03 AM
