ceddy rom WGDC fail safe lookup tabel
I got a evo V here that does not respond to the map settings,
Running the Ceddy rom,
Zero'd out all the correction tabels.
putt in say 50% in both WGDC maps's
But the WGDC are not going to 50%
The only thing i can find is this;
http://www.dsmtuners.com/forums/evos...-ceddymod.html
i have done 15+ evo.. running the Ceddy rom.
There is something wrong with this car.. and i can't figure it out.
try'd 2 ecu's and 4 roms..
everytime i get the same small dip in WGDC..
dropping to 87.5% at 3500 rpm.. and going back to 100% at 4000prm and up.
Ok sure.
Well if its following pretty much 100% duty and dipping down to 80's as boost hits before going backup, thats the standard boost tables and would relate to an XML issue.
