TephraXMOD V2
#136
#139
Using a 12vdc power adapter to bench flash...multimeter reads 16.5v output alone and 15.5v after plugging in the OP only. Is it safe for me to plug the ECU in at 15.5v without frying it? I'm sure the voltage will drop a bit with ECU and OP, but still scared to harm the ECU with that higher voltage. anyone got any input into this? Thanks
#146
#147
David thank you for all the time you have spent putting forth another great product for the Evo Community!!! We all appreciate it, Cheers!
#148
OK so I just tried bench flashing the Rom onto the ECU. Put it back in the car and i get the fans and service reminders on the display. Car tries to crank but won't fully turn over and run. I Flash this in recovery mode and ECUFlash gave the pop up that it completed successfully. It was a very slow flash from 0% to about 65%, then up to 74% really quick, and bam popup window saying it was successful. Whats the deal here, my car won't start!!!!!
This is the Task Info report from ECU Flash:
[12:35:18.992] EcuFlash Version 1.44.3721
[12:35:18.992] OS Version Windows 7
[12:35:18.992] Qt Version 4.8.0
[12:35:18.992] 63 memory models read.
[12:35:18.992] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[12:35:19.195] 612 ROM metadata models scanned.
[12:35:19.195] checksum module "subarudbw" loaded.
[12:35:19.195] checksum module "mitsucan" loaded.
[12:35:19.195] checksum module "mitsuh8" loaded.
[12:35:19.195] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[12:35:19.195] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[12:35:19.195] flashing tool "wrx02" loaded.
[12:35:19.210] flashing tool "wrx04" loaded.
[12:35:19.210] flashing tool "sti04" loaded.
[12:35:19.210] flashing tool "sti05" loaded.
[12:35:19.210] flashing tool "mitsukernel" loaded.
[12:35:19.210] flashing tool "mitsukernelocp" loaded.
[12:35:19.210] flashing tool "mitsubootloader" loaded.
[12:35:19.210] flashing tool "shbootmode" loaded.
[12:35:19.210] flashing tool "shaudmode" loaded.
[12:35:19.210] flashing tool "subarucan" loaded.
[12:35:19.210] flashing tool "subarucand" loaded.
[12:35:19.210] flashing tool "mitsucan" loaded.
[12:35:19.226] J2534 API Version: 04.04
[12:35:19.226] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[12:35:19.226] Device Firmware Version: 1.14.4004
[12:35:19.226] Device Serial Number: TA2UkRlj
[12:35:19.226] interface close
[12:35:19.257] J2534 API Version: 04.04
[12:35:19.257] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[12:35:19.257] Device Firmware Version: 1.14.4004
[12:35:19.257] Device Serial Number: TA2UkRlj
[12:35:19.257] interface close
[12:35:19.288] J2534 API Version: 04.04
[12:35:19.288] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[12:35:19.288] Device Firmware Version: 1.14.4004
[12:35:19.288] Device Serial Number: TA2UkRlj
[12:35:19.288] interface close
[12:35:45.793] 56890013 (154 tables) inheriting evo10base (320 tables)
[12:35:45.808] 56890213 (239 tables) inheriting 56890013 (316 tables)
[12:35:45.871] 1048576 byte image read.
[12:35:45.918] using metadata XML ID 56890213 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/56890213-TephraMOD.xml
which inherits XML ID 56890013 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/56890013 2011 USDM Lancer Evolution X 5MT.xml
which inherits XML ID evo10base from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/mitsubishi/evo/evo10base.xml
[12:35:55.059] J2534 API Version: 04.04
[12:35:55.059] J2534 DLL Version: 1.00.3721 Jan 9 2013 17:24:59
[12:35:55.059] Device Firmware Version: 1.14.4004
[12:35:55.059] Device Serial Number: TA2UkRlj
[12:35:57.527] sending init sequence 1 (0001)
[12:35:58.556] got 0x05 response
[12:35:58.556] sending init sequence 2
[12:35:58.556] got 0x1A response instead of 0x1B
[12:35:58.556] sending init sequence 3
[12:35:58.915] entering bootloader
[12:35:58.915] kernel read area: addr: 03FFFA len: 0006
[12:35:58.931] kernel rsp page: 030000
[12:35:58.931] kernel read addr: 03FFFA len: 06
[12:35:58.931] kernel rsp end
[12:36:00.974] sending init sequence 1 (0001)
[12:36:02.004] got 0x05 response
[12:36:02.004] sending init sequence 2
[12:36:02.004] got 0x1A response instead of 0x1B
[12:36:02.004] sending init sequence 3
[12:36:02.363] entering bootloader
[12:36:02.363] Flashing ECU memory...
[12:36:02.363] Erasing ECU memory...
[12:36:02.363] kernel erase
[12:36:13.439] kernel init
[12:36:13.454] kernel write area: addr: 000000 len: 0080
[12:36:13.454] kernel set page: addr: 000000
[12:36:13.486] kernel write area: addr: 000080 len: 0080
[12:36:13.517] kernel write area: addr: 000100 len: 0080
[12:36:13.532] kernel write area: addr: 000180 len: 0080
[12:36:13.564] kernel write area: addr: 000200 len: 0080
BLAH BLAH BLAH for 136 pages in MS Word
And the bottom:
[12:38:13.821] kernel write area: addr: 0BFC00 len: 0080
[12:38:13.821] kernel write area: addr: 0BFC80 len: 0080
[12:38:13.821] kernel write area: addr: 0BFD00 len: 0080
[12:38:13.821] kernel write area: addr: 0BFD80 len: 0080
[12:38:13.821] kernel write area: addr: 0BFE00 len: 0080
[12:38:13.821] kernel write area: addr: 0BFE80 len: 0080
[12:38:13.821] kernel write area: addr: 0BFF00 len: 0080
[12:38:13.821] kernel write area: addr: 0BFF80 len: 0080
[12:38:13.945] checksum is: FF 6D
[12:38:13.945] interface close
Is this Correct and what others are seeing when trying to flash TModV2
And the bottom:
#149
Well Sorry for posting three in a row here, but...
(My car is also Bone Stock for reference)
I put the ECU back in the car, turned to ON Position and tried to start, no luck. I decided to be brave and try other things. I disabled the recovery mode in ECUFLash and hit "Write to ECU"...it completed successfully. Turned ignition to off, and the immediately went to turn the car on...no fans running this time and so I turned it over and IT STARTED right away.
Logged a bit while it idled, nothing unusual. Start creeping forward in my neighborhood and car starts to sputter and idle weird. I try to get going a little bit more and as soon as I got over 2200 rpms the engine tries to stall out. Now the engine is idling at 2k rpms and then a SES Light. I shut the engine off and pull the DTC, P0068. I then did the drive over again after clearing the code. Idle back to normal then SES, P061A. Cleared code after driving the 25 ft back got my garage and the restarted the car and back to idling fine. Im gonna let it sit until the 2011 USDM 56890213 Rom is updated.
Tephra I emailed you about all this too, can I get that USDM 2013 rom you spoke of? My car is a DD so the least amount of down time the better. Cheers!
#150
