TephraXMOD V2
#181
I'm using the XML that tephra sent for the tmod v2 56890013. I dropped it into the Evo folder in rommetadata. Does it have to access the regular XML of 56890013 that is there when you install ECUFLASH. Do I need to erase the original 56890013 and replace it with the one that tephra sent me?
Code:
<include>56890013</include>
Attach your 56890013 XML to this post so I can see it.
#182
tephra's xml is only for his modified portions of the rom and has a line in it that calls the main 56890013 xml around line #17 if you look it will look like this:
so my guess is your 56890013.xml does not match what is in the tephra v2 xml.
Attach your 56890013 xml to this post so i can see it.
Code:
#183
if you check that xml - you will notice that there is NO "MAF Scaling" table defined..
so my XML is saying "hey use MAF Scaling and add a few more attributes", and Live Tuner is saying "But there isn't a MAF Scaling defined at all"
the quick work around is to remove the MAF Scaling line in the V2 XML - just means you wont be able to live tune it
the fix is to find a MAF Scaling entry that you can put into the 56890013 xml and then ensure V2 XML has the same named entry..
#184
I will update you on the 3 patches/fixes you sent me tomorrow.
#185
Looks like you are using ECUFlash out of box XML, I highly suggest you use Golden's version instead. I haven't checked it in a while but my XML for that ROM started from his then I defined all tables that have been published publicly for other ROM's. If you need that let me know and I can share it.
Or at the very least at this to yours:
Code:
<table name="MAF Scaling Horizontal" address="575ae" category="Fuel" type="2D" scaling="GramsPerSecond"> <table name="Volts" address="62014" type="X Axis" elements="130" scaling="VoltsADC1023"/> </table>
#186
The portion you deleted from tephra's XML is the portion that enables live tuning so you'll want to add that back and correct the actual issue if you plan on live tuning the car.
Code:
Where am I adding that coding to Goldens XML or tephra's XML? Also where in the XML does this need to be placed?
#188
1.44.3721 from tactrix website. I got it figured out now. Had to add the code that you posted on the last page and with it in golden's XML also. Live tuner opens the ROM file correctly now. I really appreciate all the help guys. This adding lines of code stuff is a little new to me. Thanks!
#189
So is the 56890013 ready? If so when will you send it tephra?
#190
#191
#192
So question about the v2. I'm scheduling my recall for my CMC soon and if I have the v2 on the ECU, will the dealer be able to reflash it back to an oem ROM? I'm going to let them know not to reflash, but even if they do. Shouldn't it not work anyway without a bench flash to the ECU?
#193
My dealership knows me so they do not mess with my car and didn't attempt the flash when I was there.
Bottom line dealership flash method won't have restrictions ECUFlash has and will overwrite it if they perform it. Best option is to refuse it and hope they don't do it anyway.
