TephraXMOD V2
#332
yea, though it's split up to 3 tables and naming convention is a bit different due to that. looks the same as the supplied "evo10base.xml" file.
<table name="MAF Scaling Horizontal" address="575c6" category="Fuel" type="2D" scaling="GramsPerSecond">
<table name="Volts" address="6203c" type="X Axis" elements="130" scaling="VoltsADC1023"/>
</table>
<table name="MAF Scaling Part 1" address="575c6" category="Fuel" type="2D" level="2" scaling="uint16">
<table name="Volts" address="6203c" type="Y Axis" elements="44" scaling="VoltsADC1023"/>
</table>
<table name="MAF Scaling Part 2" address="5761e" category="Fuel" type="2D" level="2" scaling="uint16">
<table name="Volts" address="62094" type="Y Axis" elements="44" scaling="VoltsADC1023"/>
</table>
<table name="MAF Scaling Part 3" address="57676" category="Fuel" type="2D" level="2" scaling="uint16">
<table name="Volts" address="620ec" type="Y Axis" elements="42" scaling="VoltsADC1023"/>
</table>
and just to verify, the scaling is defined:
<scaling name="VoltsADC1023" units="Volts" toexpr="x*5/1023" frexpr="x*1023/5" format="%.2f" min="0" max="5" inc="0.05" storagetype="uint16" endian="big"/>
</table>
</table>
</table>
</table>
#333
Tephra, thanks for V2!, I am having a couple problems though. When using NLTS, it seems to be ignoring the rpm drop setting. I have tried 1000, 2000, and 3000 rpm drop, and it seems to drop to 6K rpm and then bounce there, no matter what RPM I clutch in at. I have min rpm to engage at 6k, if that matters.
My other issue is with live tuner. It doesn't want to connect. It will say openport 2.0 connected when i first open the program, but then will go to not connected, and flip between connected and not connected. I haven't been able to get it to work. I don't have any problems logging with evoscan.
I have a 2010 USDM GSR
Any idea what might be my issue?
#334
#335
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
58010205 xml is referring to "MAF Scaling", it expects that that table will be defined in the parent XML's, which isn't the case.
If your using "MAF Scaling Horizontal", then just update the V2 XML to refer to that one instead
#336
#337
#338
#339
ok, The LT app (like ECUflash) detects when the OP20 cable is plugged into the computer.
the connect and start logging buttons will "enable" when the OP20 is plugged in.
if its going connected/not connected then either something is interrupting it, or the cable is dodgey... i think it checks every 1/4 (or maybe 1/2) second, which i think is a bit more often that ecuflash...
can you try another USB cable?
#340
#341
yeh.. a "bit different" is what the problem is.
it works now. loaded rom and connected to live tuner for a second before i went to work.
THANKS!
