TephraXMOD V2
#91
Wow, looks like you have been busy Tephra, great to see V2 have so many new/awesome features.
If I ever put my evo back together I will be sure to buy/donate for this as I love my v1.
#98
#101
#105
Off topic, but it's an Evoscan issue. Easy fix is to have Evoscan extract both odd and even data from these requests: input shaft, slip, pressure and clutch temp. Today, for example, if you want odd clutch temp, Evoscan does a query saves the odd temp then discards the even temp. Later you request even clutch temp and it redoes the query. I tried to use its "CALC" function developed for RAX patch, but Evoscan treats bitfield values as unsigned. For SST values, it needs to cast as signed, otherwise the negative values are messed up.
