59580004 - Various Defined Tables
def
hey just wondering if you play around with the n/a lancers at all? i have a 2010 lancer es cvt 55180006 and im just trying to edit timing, fuel and throttle maps but cant find a def that works any help will be appreciated
Boost Limit Rescale:
Code:
<scaling name="BoostLimitRescalePatch" storagetype="bloblist"> <data name="Patch disabled" value="5942"/> <data name="Patch ENABLED!" value="5943"/> </scaling> <scaling name="LoadBoostPatched" units="%" toexpr="x*5/2" frexpr="x*2/5" format="%.0f" min="0" max="638" inc="2" storagetype="uint8" endian="big"/> <table name="Boost Limit Rescale Patch (F1 for Help)" category="Turbo Boost Limit - Rescaled" address="1c7a8" type="1D" scaling="BoostLimitRescalePatch"> description>Once ENABLED, the [Boost Limit - Rescaled] table replaces the original [Boost Limit] table. Maximum load will then be able to exceed 319.</description> </table> <table name="Boost Limit - Rescaled" category="Turbo Boost Limit - Rescaled" address="555b4" type="2D" scaling="LoadBoostPatched"> <table name="RPM" address="61f40" type="Y Axis" elements="9" scaling="RPM"/> </table>
Code:
<scaling name="BoostLimitRescalePatch" storagetype="bloblist"> <data name="Patch disabled" value="5942" /> <data name="Patch ENABLED!" value="5943" /> </scaling> <table name="Boost Limit Rescale Patch (F1 for Help)" address="1c7a8" category="Turbo Boost Limit - Rescaled" type="1D" scaling="BoostLimitRescalePatch" description="Once ENABLED, the [Boost Limit - Rescaled] table replaces the original [Boost Limit] table. Maximum load will then be able to exceed 319."/> <scaling name="LoadBoostPatched" units="%" toexpr="x*5/2" frexpr="x*2/5" format="%.0f" min="0" max="638" inc="2" storagetype="uint8" endian="big"/> <table name="Boost Limit - Rescaled" address="555b4" category="Turbo Boost Limit - Rescaled" type="2D" scaling="LoadBoostPatched"> <table name="RPM" address="61f40" type="Y Axis" elements="9" scaling="RPM"/> </table>
