CEL P0122 - TPS - disabling it through Periphery bits?
Hi guys,
I am getting a P0122 - Thottle position Sensor Circuit low input CEL, and i cannot clear the code... keeps coming back
The car idles perfectly, and runs perfectly.
I know you can disable some codes through the ECU Periphery bits, but I haven't found one for the P0121 and P0122 codes.
Can anyone chime in on this??, anything I can change in the ROM to get rid of this CEL?
Again, the car is running perfectly.
Thank you!
Thank you!
I have an OBD2 reader, and it is able to read TPS, RPM, etc,
With the car OFF, ignition ON, the OBD2 scanner is reading the Absolute Throttle Position at 0.
When I go WOT, i get to 99.22
It seems like it is calibrated well, and responds to pedal movement well :/
Mitsulogger 2.0 fails to detect my tactrix 2.0
Any help?
Thanks
Any help?
Thanks
Update guys:
I was testing the TPS, and at WOT I am getting 4.7v, and without touching the pedal, I am getting 0.2V, which is low. At idle the TPS should be reading about 0.5V right?
Going to adjust it now.
Update:
Fixed the code. I had a lot of trouble testing the actual TPS. I did not want to poke a hole in the middle wire that was sending the voltage, so I disconnected it and connected the sensor and plug with 2 small wires, and my volt meter in the middle..
Was getting 5V constant, then 0, and connection was not good....
Scrapped that idea and then just plugged in my OBD2 reader, (reads the TPS), so I just rotated the TPS around until it was at %10 throttle at idle. Cleared the code and it never came back.
