Ceddy rom (sas settings)
What's everyone's sas settings and timing tables?
I've got a bov on ATM and it only bangs the once so I'm switching back to recirc and I've drilled the sas bolts out to 6mm.
I'm doing the due maps one for pops and bangs and the one without,in wanting I to pop like crazy on over run and gearchanges.. And down low too if I possible !
This is the current table of mine :
Try and tune the system around a maf hz reading. You want to make the maf read a bit higher than with the system off. You can tune fuel that way to benefit your set up. Provided you are in open loop at those points. I've done some tinkering with it. I think with no air just the negative timing I gained 50ish hz. You want to waste more air through the system so you don't stall the compressor. Essentially a boost leak. I've hooked it up to my vi-pec.
I thought the ceddy could do -27!?
Rick2020 (Jun 17, 2023)
So without the SAS the air injection won’t work, but you can still use the SAS function as a way to trigger the injectors to continue spraying fuel on decel. There may be another way to disable fuel cut on decel but I haven’t found anything yet.
Also, if you want to have timing lower than -10 you will have to add a patch to your xml file. Just be aware that if you do, the ecu could potentially retard the timing that low due to knock/octane level.
Ceddy can do -27, but only while using the launch control. Ceddy is still limited to -10. I was able to get around it with an xml patch though.
Btw, do you happen to know the difference between valid trigger time and minimum trigger time?
FS[SouthEast]: Valve Cover (VIII), trim, PCV
superbovine
Dec 12, 2016 03:34 AM
FS[SouthEast]: New NASCAR Craftsman Truck - Road Course
Joeekrub
Aug 17, 2016 07:00 AM
