Viewing Data of Map
Old Jan 17, 2015 | 07:55 AM
pog0's Avatar
Viewing Data of Map
I used to dabble in this back in the day when ECUFlash first came out and it sure has changed. I remember that I had to edit my XML file for my definition (88590715). I found an edited XML file and loaded the tables into my XML. Now when I view certain fields, it does not display all the data. See pics 1 and 2.
While poking around, I noticed that my alt map (presume e85 map) RPM is all over the place. It doesn't look normal and could be that I added someone's tables into my XML file, pic 3.
http://imgur.com/a/WHMgt
I don't plan on editing much, except for lowering my idle and maybe just to learn a bit more. I can't adjust the window size like normal windows. I run ECUFlash 1.29a since I have the older 1.3U Tactrix cable on Win 7 x64. I can upload my XML file if needed, but I essentially copied just the tables from this:
https://code.google.com/p/ecurom/sou...15-v7.xml?r=55
Old Jan 17, 2015 | 02:56 PM
CDrinkH2O's Avatar
Either your ECU binary is corrupt or your XML file is wrong. Did you copy the XML file into your metadata directory (usually at C:/Apps/OpenECU/EcuFlash/rommetadata/mitsubishi/evo) ?
Old Jan 17, 2015 | 07:41 PM
pog0's Avatar
I copied the XML file and I also tried just copying the tables from the XML file into the existing 0715 XML. Both give me the same result.
Old Jan 17, 2015 | 08:49 PM
ronaldo9's Avatar
I wouldn't touch the alt map. Is the car running ok? Just leave it alone and adjust the idle like you said you would.
Old Jan 18, 2015 | 12:09 AM
french's Avatar
So you have a tephra rom ? The xml you are using is for a tephra modified rom.
Old Jan 18, 2015 | 09:02 AM
pog0's Avatar
Ronaldo,
I was just poking around to look at it. I don't plan to mess with the tune at all besides idle. I was just looking at the fields and noticed it was strange.
French,
Yup. I have a dual map e85/91. Mainly runs on e85.
Old Jan 19, 2015 | 12:21 PM
french's Avatar
The tephra v7 page recommends ecuflash 1.41 or better. Maybe your issue is with your ecuflash version. Try a later version to edit your rom and use the older version for flashing.
Old Jan 20, 2015 | 10:53 AM
pog0's Avatar
That did it. Thanks for the info. Lots of cool stuff to research now.
jogi_rm
Sep 18, 2014 03:52 AM
jogi_rm
Sep 17, 2014 10:33 PM
DhiJay23
Outlander Sport
Apr 23, 2014 11:46 AM
bahnzii
Jan 10, 2011 07:54 AM
Quick Reply: Viewing Data of Map
