EvoScan 2.9 Error: errors were found in the original data.xml
I'm unable to edit/add Data Items- when I attempt to do so I see this:
I've pretty much tried everything that I can and no luck- figured I'd post here in hopes of one of you guys having any insight...
bump- anyone?? i' opened a trouble ticket a couple days ago with evoscan, still no reply. at this point the software is completely useless to me if i can't edit/add data items. is there a way to enable debug mode so i can see exactly what's triggering this error?
Something must be wrong with the data item your attempting to edit "Timing Alpha". Make sure you have your entries set correctly for any changes you made, otherwise delete all entries for Timing Alpha so it's blank so you can go back to the main screen.
Thanks for the suggestion- unfortunately that's not the problem. I've tried reinstalling multiple times with different versions and have also tried to delete all items and/or all but one item that I know is configured correctly and I still get that error...
Just noticed this thread a few posts down: https://www.evolutionm.net/forums/ec...a-xml-mac.html
Looks to be some kind of bug. I would suggest reinstalling/finding a clean xml data file for the parameters and manually editing the data as suggested in post #1 Solution until Hamish can resolve the issue.
TariqEvo
Sep 24, 2017 08:15 AM
