Grimmspeed EBCS over boosting
Old Aug 4, 2015 | 09:56 AM
03Ev0luti0n's Avatar
Kind of lost on this...
Running Tephra V7 and ECU controlled boost on a BW 7670 w/ Dual EWGs.
Was running the EBCS as a 2 port system (top port of EWG was vent to atmosphere) car was extremely laggy but made boost and held great at roughly 40% WGDC. It just wasn't very consistent. Target would vary between 18-25 lbs.
I changed the WG plumbing to a 3 port system as I was told it may help with lag and more consistent boost curve. I zeroed BEC table and set WGDC to 5%. No it's boosting to 30 psi consistently at 5% WGDC?
When I was running a stock turbo I had to drop my boost adder to 10.6 to keep the stock turbo from over boosting at just 50% WGDC despite living in Atlanta, GA and no where near that high of an elevation. Do I need to just keep dropping the Boost Adder? My target boost is set at 24.9psi
Old Aug 4, 2015 | 01:32 PM
solved the issue.. not sure if anyone else has had this issue.. JeffBeagley posted a diagram of Tial EWGS run to Grimmspeed EBCS. it can be found here:
https://www.evolutionm.net/forums/ec...l#post11487987
The grimmspeed doesn't come with a diagram how to run 3 port on EWGs. not sure if anyone else is having or had this issue.. Grimmspeed shows port 2 as the charge port but it is actually the vent to atmosphere port.
DBallz
22
Nov 12, 2015 08:32 AM
Evil_Rs
Aug 3, 2013 12:44 PM
hachansoo0413
Aug 24, 2012 09:12 AM
Quick Reply: Grimmspeed EBCS over boosting
