Odd MiVEC logging/p0011 code
So I finished my 2.4LR build a couple months ago and really the only issue is I'm getting a P0011 code (ie mivec slow to respond).
I'm not sure why I'm getting it. If was an issue with having to alter the timing by a tooth for the 2.4 build I think it would be more documented so I don't think that is it. I also don't tihnk it's an issue with the intake cam position sensor being installed 180* off because I feel like there would be more symptoms with fuel delivery, etc
The cars idles odd sometimes (after driving for a while and after getting new gas for a minute or so) but otherwise there seem to be no symptoms other than the code itself.
I tried logging MiVEC using the method I've found but I seem to be getting odd logs of it so perhaps I'm not doing it correctly or it's pointing to another problem.
I uploaded a log which shows mivec. I'm not sure if the values I'm logging are correct and there is a mivec issue (perhaps the sensor is installed 180* off) or if I'm just not logging correctly. The formula I'm using is 72-0.6*x/32 and I'm using 7650 and 7651 on MUT locations B0 & B1 (which are unused as far as I can tell). I haven't made any other changes to xml files but I haven't seen anywhere that you need to.
Any help is appreciated
TKPIXMR
Jan 2, 2010 07:00 PM
