18.4 AFR off Throttle
It's normal for AFR to read lean when off throttle right? I just wanted to make sure because I am tuning some really low load cells of my VE table and if excluding all the 18.4 readings I need to lower the VE a lot there but I wanted to make sure the 18.4 was normal before I ignore them and tune off the other values.
AFR should read full lean if you're off throttle.
Ok. Cool. Thanks. That explains why I've had issues tuning the low load part of my VE table. I was going off averages from Evoscan and those were being skewed lean by off throttle 18.4s. I'll start ignoring those. I appreciate all the help you've given me with different things over the past few weeks.
MRGEVO
Feb 28, 2011 05:40 PM
