Tephra V2 Launch Control problems and inconsistent.
I have been testing the launch control maps and it does what it needs to do for just 2 or so seconds. When i get into LC mode it bounces off the set rev limit then shoots into a free rev and i dont have a rev limit till i turn off the car and turn it back on.
If i get on and off the throttle quickly keeping it in its window it wont do it. But if I hold it or try to, it wont for very long.
Has anyone been able to use it consistently as it should?
i've seen this once before, but ive never really tried to replicate it...
the code is very simple, basically examines TPS and clutch down... i think perhaps the TPS is being pulled back by the ECU.
can you log TPS while your doing it and see if that drops below the threshold?
Settings that I remember for that one car
tps enable for LC = 50%
Speed = 14km/h
I just blew it off as maybe there is a subroutine parameter in relation to max rev limit * duration before it disables LC for X amount of time
CT9A PR
Apr 27, 2020 11:53 PM
moreno78065
Jun 18, 2015 07:20 PM
