Help tuning evo 6
Help tuning evo 6
Hey guys i am trying to tune my evo 6 i have ecuflash , tactrix 2.0 cable and i currently have a rom from evoscan with launch control enabled. i have changed some small things like speed limit, stat idle with ac. i cannot get the stat rev limiter to work it just flies passed my setting at 4500rpm, i have launch control speed at 4km/h, timing retard at -5, anti lag start is at 4200rpm. not sure what else i need exactly any help would be much appreciated. also i have tried with clutch in and e brake up doesnt change anything.
You will need to use the CeddyMods ROM which is a dual map ROM that has launch control with appropriate switch wiring to the ECU. Go to the Geekmapped site for lots of helpful info on this setup in a Evo5-6.
Kevin@MellonRacing
EvoX 'For Sale' Services
Aug 12, 2009 08:41 AM
AbrasEvo
Apr 18, 2009 10:01 AM
