E85 built motor missfire problems
Old Apr 17, 2016, 06:12 PM
evl gsr's Avatar
Hi All,
Getting a little frustrated at a problem i have been having for a while now which i cant get my head around, hoping someone here has gone through something similar or know about the issue.
The problem is apparent if i run anything higher than 19 psi the car will misfire or stutter. The only thing that has fixed this issue has been a test run that i made with minimum ignition retard limit set to 10 degrees, doing this allowed me to hit 24 psi with no stutter. Anything under 10 degrees has caused the issue to come back. AFR's are correct all through the rev range. MAP and MAF counts are very similar to each other. When the issue occurs the AFR's dont show any signs of lean or rich conditions and there is no nock in the logs.
the car is an evo 6 with a high compression setup using the standard ecu and ceddy's SD rom, car runs a pro12 CDI.
Things i have tried that have not fixed the issue.
Switching ROMS from SD to MAF etc
changing plugs
switching to oem coils
changing plug gaps
Thanks in Advance for the help.
Old Apr 20, 2016, 10:23 AM
lancerrally45's Avatar
Is it timed correctly?
Old Apr 20, 2016, 11:57 AM
evl gsr's Avatar
Yep we timed according to GSC cam spec sheet.
evl gsr
Apr 20, 2016 02:30 AM
timschot
For Sale - Cars For Sale
Jul 18, 2014 12:27 PM
delkat
25
Nov 22, 2011 12:46 PM
Evoovasti
Apr 9, 2009 11:24 PM
Quick Reply: E85 built motor missfire problems
