Speed Density Idle problem ( 70 LOAD- 10.5 AFR )
Hello Guys,
After 5 days my Evo 8 with speed density running!
Car running at idle with 70 LOAD(95Hz airflow) instead 30, and 10.5 AFR instead stoich.
What's wrong? Seems needs a sort of calibration MAP -> LOAD ?
Thanks
Thanks
Just noticed that you said after 5 days like this was a problem that just came up after 5 days of running differently on the same tune? If that occurred you might have a mechanical issue.
Ohh no sorry! 5 days to male a conversion...today is a first day that i run with SD
I was trying to edit posts because reading replies you made right as I posted so messed the order of posts up a bit.
Try RPM VE 500 to 2000 as 64, 67, 70, 75, 80 and see if that leans it out any.
Bump
im having a similar issue with my load, it's 44% at idle and the car uses mid LTFT at idle and sometimes goes to low, any ideas? Did raising your RPM ve tables a bit help as suggested?
Need to change the crossover points for your fuel trims. It shouldn't go to mid until like 55-60 load.
