Evo 8, SD, S90 70mm, ASNU 1050cc : top lean tip-in
Hello,
From converted car to SD I always suffered about lean afr during tip-in.
Now after switching to ASNU 1050cc and FIC resistor box this behavior is much worse.. Too lean in tip-in.
Max IPW accel enrich : 4.61ms
Moltiplicator : from 0.38 to 0.70
TPS delta : + 30 units to all table.
Any suggestions ?
Any suggestions ?
This thread will help. Lean tip-in was a common problem so you'll find lots of discussion about it.
https://www.evolutionm.net/forums/ec...ched-roms.html
If your rom has the 3D RPM vs. VE table you'll have more adjustability, but the 2D table in the earlier rom works just fine.
jameswwt
Jun 14, 2012 08:55 AM
jonny2735
10
May 18, 2012 12:20 AM
Mike01gsr
Apr 20, 2011 09:52 AM
