Swapped to SD, great cruise and Idle, AWFUL WoT (rich)
Good evening everyone,
I recently made a swap to SD because the MAF was giving me so many headaches on my 7163 setup. It was idling everywhere, causing issues with idle RPM, cruise would lean out on tip in, etc. Anyway, switching to SD fixed it near instantly. Trims between -1.8-and +2.
Anyway, I noticed however that as soon as I get into any sort of boost, it immediately goes dead rich, to the point that the car pulls timing, and literally stops making power. I obviously haven't kept trying outside of a few pulls, so I wanted to see what everyone thinks here. The issue starts around 3500 RPM, and will not go away. No knock, just timing pull.
My current MAP VE table are all 1:1, and I've adjusted the RPM VE table up and down with no success. Fuel injectors are FIC 1000s scaled to the example in the supermerge.
Any ideas what the issue could be?
EDIT: Using Omni 4bar
I'm pretty sure I've got it in working order now. WOT pulls are much better, and just need fine tuning once the car is fully ready to tune.
For anyone experiencing this (as the only forum post i saw about this ended abruptly), basically just lean out injectors, and latencies, reset the VE and go from there. Takes some patience, but I got it to where it needs to be in all phases.
Very soon in fact!
R/T Ernie posted about our bad dyno day in the EFR thread. I tried to use the IWG that it came with and it literally fell flat on it's face after 20psi (as in spiked to 20, and immediately dropped to 10psi to redline). I just got the Turbosmart twinport, and will be installing it soon, and then it's back to the dyno.
At the end of the day we just tuned the boost down all the way, and decided to try another day. The results will get posted there ASAP.
Well, see that was the issue. The VE table wasn't getting rid of that dead rich WoT unless I went into crazy type numbers on the table. That's why I ended up leaning out globally with the injectors and then going back to the VE, resetting and dialing in from there.
Hotsauce101
Jul 23, 2015 11:57 AM
usernameinuse
Sep 24, 2012 01:12 PM
scott71785
May 21, 2008 11:48 AM
