Omni 4bar readings Vs Boost guage readings.
Just installed omni 4 bar. Doing some logging at idle. Its reading -8.5 ish but my boost guage reads -15 at idle.
This is for rom 96530706.
Do you need to change formulas? Or is this accurate info?
I read on here for my rom just input the formula into evoscan and it just works.
Clarify please? Manufacturer of your boost gauge? I am assuming your utilizing PSI calcs? You need to edit the equation in evoscan to represent your ambient PSI.
My gauge reads 12 vacuum at idle, and my evoscan registers -4 ish. During a pull it registers boost correctly within very close reason to gauge vs. evoscan.
4b11slayer (Sep 29, 2016)
Its a mechanical 30 psi autometer guage. I have cams so i am seeing -15 inches of vac on my mechanical guage. Just installed omni 4 bar to log boost.
Evo scan 2.9.
Logging Omni 4 bar in evoscan. Request 38- Function 0.2369*x-14.7 Units psig.
I havent compared boost readings but right off the bat im only seeing about -8.x inches of vac via evo scan and omni 4 bar.
![Beer](https://www.evolutionm.net/forums/images/smilies/beer05.gif)
I assume that you are confused by the readings you see.
The Gauge reads : -30 inHg --- 0 inHg/Psi --- 30 Psi
-15 inHg equals about -7.5 Psi at sea level.. so different scale..
Evoscan read only PSI
0 PSI = 0 inHg
-7.5 = -15 inHg
-15 PSI = -30 inHG
you get it....
0 PSI = 0 inHg
-7.5 = -15 inHg
-15 PSI = -30 inHG
you get it....
4b11slayer (Sep 30, 2016)
Ahhhh i see now... Thanks Germ
itsmrrizz2you
10
Sep 11, 2014 08:52 AM
robyn402
Aug 13, 2010 07:07 AM
Thugline
Mar 14, 2010 01:59 AM
