Big Map Translator
Big Map Translator
Whats up yall.
Im attempting to tune a evo 8 on 94170008.
Im having issues with the Big Map Translator I downloaded from one of Tephras posts.
I copy and paste my ecu flash Timing map and I get provided with a new BIG map but says the data copied is not the same shape or size of new map or something.
And if I copy and paste my High octane map it seems to carry over timing numbers.
If you read the statement between the two maps on the translater ti tells you," Note: Excel will automatically display decimals points if any the lowest value is above 7, just copy your fuel map in as an example "
Evo 8 maps are smaller than what the translator has. if you look at the top map of the translator. it tells you what to do in the grey section. <<<<<<<<<<<<<<<<<< COPY 1000000 into the last column/row, IE if you have a smaller map then move the RPM AND LOAD final axis value up
4b11slayer (Nov 17, 2016)
