STFT max + with 3D sd
Hi all,
So i have been trying to tune 3D sd on 2150s [ pump gas ] idle and cruise.
I am constantly getting STFT Max +25-22 at idle and cruise. I have de-linearized map volts to kpa & kpa to load values in cruising areas.
So the question is.. Is there any relationship between map volts to kpa fueling and STFT ? or it is purely Scaling and Latency related.
MAP volts to KPA does affect load, however you shouldn't have to touch that table unless you really have to. If you are trying to adjust your fuel trims stick to tweaking the injector scaling and latency tables.
negativegeforce
Jun 20, 2010 02:24 PM
